Author Topic: Adverts not working  (Read 5008 times)
Offline angrykid
Adverts not working
« on: February 03, 2008, 05:02:03 pm »
Hello. I am requesting help in behaf of my friend that pasted what I wanted to say to ULX tech support.
I have an issue with ULX SVN not showing messages I have set up. Yes, I am using the latest version. I have tried to set the following messages in server.ini;
ulx addAdvert "Hello. And welcome to to %host%." 10 a
ulx addAdvert "Your body has just been scanned and you are clear to play on this server." 10 a
ulx addAdvert "This listen server is currently playing in the map: %curmap%" 10 a
ulx addAdvert "A reminder to all visitors at %host%. You will be *garbled words*, and then their will be cake." 10
But they refuse to work. So I'm requesting help on this. I am running threw singleplayer expecting them to work, and there is nothing that states the messages only work when running a server.
I have sent my condump in hopes to fix this issue. Thanks in advance.
« Last Edit: February 03, 2008, 05:09:23 pm by angrykid »
Re: Adverts not working
« Reply #1 on: February 03, 2008, 05:10:38 pm »
Have you tried running it on a server regardless? How ULX functions in singleplayer is undocumented and unsupported.
Offline angrykid
« Reply #2 on: February 03, 2008, 05:16:21 pm »
Hold on, he's being difficult.
Offline angrykid
« Reply #3 on: February 03, 2008, 05:25:54 pm »
Okay, it did work. Something with SP. I'll test it myself and see if they work in SP.
Offline angrykid
« Reply #4 on: February 03, 2008, 05:34:30 pm »
It worked for me.
Worked a fix out, and testing it now. You can delete this if you wish.
« Last Edit: February 03, 2008, 05:49:04 pm by angrykid »
