Author Topic: RadioMod ulx addon  (Read 35983 times)
Offline high6
RadioMod ulx addon
« on: February 06, 2008, 09:56:24 am »
Requires:
1.FM addon
Commands
ulx music <provider> <station> <quality> - Play station
ulx musicurl <url> - Play url, NOTE! You must remove http:// at the front, otherwise ulx with split it and mess the args up.
ulx musicstop - Stop music
also about url
(Remove all hex codes such as %20 and replace with the character, example being www.somesite.com/this%20song.mp3 to www.somesite.com/this song.mp3)
Q: I can't use the commands and I am admin
A: I have access sent to none by default, so either add it to the group manually in the text file or use ulx userallow "name" "ulx music"
nomusic doesn't work right now, I will fix later.
« Last Edit: February 08, 2008, 04:17:05 am by high6 »
Re: RadioMod ulx addon
« Reply #1 on: February 06, 2008, 12:11:40 pm »
Once again, another quality release by high6!
quotable
« Reply #2 on: February 08, 2008, 08:37:51 am »
can it play web radios?
Offline high6
« Reply #3 on: February 08, 2008, 01:12:21 pm »
That is what the stations are so yes.
Offline Ninjadude101
« Reply #4 on: February 09, 2008, 08:00:54 am »
Clientside or Serverside?
If clientside please make a serverside one where the clients can play music, but the admin has an option to play music to every player
or something..
« Reply #5 on: February 09, 2008, 10:04:18 am »
Ninjadude, "ulx sound" already does this. Every player would have to have the same sound though, so if it wasn't a game sound, they'd have to download it.
Which is why 99% of music mods are clientside. Streaming music would take much more bandwidth and server resources than most game servers have.
« Reply #6 on: February 09, 2008, 10:31:44 am »
when i had a css server, mani_admin or whatever it was called had a radio script where each player types !rock, !club or whatever to get their music up, they close the window which pops up and then it continues playing. This was great.
If you could do something like that, but have an extra command which is admin only,  (!rockall, !cluball etc) which basically does the command on all client's consoles, thaat would be good.
« Reply #7 on: February 09, 2008, 04:26:46 pm »
ulx cexec <all> "ulx (music or musicurl) [url or station]"
Basically, ULX already has this too.
You'd have to make sure the clients downloaded this client side script.
« Last Edit: February 09, 2008, 04:28:38 pm by JamminR »
Offline high6
« Reply #8 on: February 10, 2008, 09:08:07 am »
I know, but I can on adding a vgui later.
Also you can give them access to this without giving them cexec access :P.
« Last Edit: February 10, 2008, 09:23:52 am by high6 »
« Reply #9 on: February 10, 2008, 09:51:31 am »
High6, I was answering Ninja's question. He wanted admin only. :)
I personally don't like admins forcing my music choice. I listen to my own, and normally have game sound turned down.
« Last Edit: February 10, 2008, 10:39:24 am by JamminR »
Tim
« Reply #10 on: March 11, 2008, 04:47:12 pm »
Someone able to get a hold of the original 1.FM mod? the link in first post no longer had the download.
« Reply #11 on: March 11, 2008, 07:03:43 pm »
Tim, seems as though High6 has repaired it.
Guy
« Reply #12 on: June 26, 2008, 12:51:15 am »
Which folder does it go into, and please make list of all the commands, please.
Offline zoombahh
« Reply #13 on: July 14, 2008, 11:09:09 am »
Quote from: high6
Commands
and folder i guess addons, since it seems (correct em if im wrong) to just be an aditional lua file wihc integrates into ulx.
notyouraccount
« Reply #14 on: August 31, 2008, 01:45:56 am »
I have uploaded this to my server and have added my own radiostation to it. But when I type every combination of !music nysradio 1 high     nothing plays. The only way I can play it is by typing !musicurl .... Can someone please help?
