Author Topic: ulx+ulib does not work when i run my gmod 10 server  (Read 11551 times)
xxgodsmackxx321
« on: February 10, 2008, 07:15:17 am »
i redownloaded ulx+ulib 4 times and it does not work on my server. it has all the files and is placed into addons. any suggestions on how to fix this?
Re: ulx+ulib does not work when i run my gmod 10 server
« Reply #1 on: February 10, 2008, 09:00:57 am »
Any errors?
Offline redbaron2005
« Reply #2 on: March 02, 2008, 06:46:39 pm »
I have same problem,
No errors, then I even try to type "ulx" in the server console it says  Unknown Command
Its installed correctly, I didn't edit ANYTHING...
« Reply #3 on: March 02, 2008, 06:47:04 pm »
Is ULX installed?
« Reply #4 on: March 02, 2008, 06:47:54 pm »
Yeah dude, and ULib
« Reply #5 on: March 02, 2008, 06:57:41 pm »
forgive us when we are skeptical when you say "IT Does NOT work.." when it clearly works for so many of us...
Without errors, it could be one of any endless number of problems... more likely than not... user related. You probably have an old version by mistake or simply installed it wrong.
« Reply #6 on: March 02, 2008, 07:00:55 pm »
I'm sorry you misunderstand me I know what I'm doing, I'm just looking for some help.
Offline spbogie
« Reply #7 on: March 02, 2008, 07:14:29 pm »
What exactly did you do to install it? Listen or Dedicated server? Where did you put the files? What other addons are you running? What have you tried to fix it yourself?
Basically, WHAT INFORMATION CAN YOU GIVE US TO ASSIST YOU IN SOLVING YOUR PROBLEM?
« Reply #8 on: March 02, 2008, 07:21:19 pm »
When you server starts up, ULib will load, and then ULX, both paste information into the server console.
If it doesn't load, an error will appear.
Please post the first 30 or so lines of your server console at the point where it says Lua 5.1 inistiallized at server startup to help indicate where ULib and or ULX is having problems, or loading properly. Either way, us seeing it will help start the troubleshooting.
Saying "it doesn't work" is no help at all.
Don't expect to call your dr on the phone and say "it hurts, any ideas" and get an answer straight away.
« Last Edit: March 02, 2008, 07:24:03 pm by JamminR »
« Reply #9 on: March 02, 2008, 07:51:39 pm »
Here is the FULL start list.
http://i22.photobucket.com/albums/b348/redbaron2005/ServerSartup.jpg
I have...
ULX & ULib in the Addons folder (X/srcds/orangebox/garrysmod/addons)
This is a dedicated server.
Gamemode: sandbox
Other Addons: assmod, Uclip, sui_scoreboard, And the Content mods.
« Reply #10 on: March 02, 2008, 08:21:51 pm »
ULib isn't loading at all.
Make sure you have, on your server,
X/srcds/orangebox/garrysmod/addons/Ulib/info.txt
« Reply #11 on: March 03, 2008, 09:06:16 pm »
http://i22.photobucket.com/albums/b348/redbaron2005/Everything-Yo.jpg
It Is, as you see in the link above...
Its really garrysmod2 but, I call it garrysmod
« Last Edit: March 03, 2008, 09:08:31 pm by redbaron2005 »
Offline Chironex
  • Formerly known as Kyzer
« Reply #12 on: March 03, 2008, 11:29:15 pm »
Lol you have 3 admin mods. Maybe that's the problem :s
« Reply #13 on: March 03, 2008, 11:54:00 pm »
**Only 2, ULX & ASS, the other is jus some proprotection.
You could be right, but I could doubt that, it would at least start the at least 1 lua file from ULX or ULib
« Reply #14 on: March 04, 2008, 12:18:36 am »
I fix it,
It seems I can't see if my command says (-game garrysmod) or (-game garrysmod2) :D
I LOVE YOU ALL!
