Author Topic: Ulx not loaded on map change...  (Read 6892 times)
Offline zpalez
« on: February 12, 2008, 02:13:30 pm »
Hi In my Gmod 10 Server ULX works fine until... I change the map... Then when the new map is loaded i press my bound admin key and it says unknown command ulx menu...
GAME MODS
- Wire Mod SVN
- ULX (non svn)
- Stacker
- Keypad
- Simple Prop Protection
- PHX 2
Anyone know how to fix this, sorry there is probably some thread that tells how to fix this that i am overlooking, but i am new to admining a gmod 10 server, but i have been managing CS:S one for a year.
Also I went in a Trickys Tutorials Server.. and the admin in that server when you pressed tab was labeled Administrator and had 500 hp... How Can i Do that.
Thanks in advance.  :)
Re: Ulx not loaded on map change...
« Reply #1 on: February 12, 2008, 03:35:57 pm »
What errors show in server console at startup of server and client console when you connect to it?
« Reply #2 on: February 12, 2008, 03:50:51 pm »
UTeam
Offline zpalez
« Reply #3 on: February 12, 2008, 05:36:13 pm »
Says Unhanled Item ulx.file
Like 1 thousand of those just with different folder locations and file names
« Reply #4 on: February 12, 2008, 05:52:07 pm »
Please give the exact error.
Nerdygamer
« Reply #5 on: February 16, 2008, 01:38:30 am »
OK i found out that a simple get out of the server and go back in will fix the problem. ;D
« Reply #6 on: February 16, 2008, 05:43:52 am »
What version of ULX are you running?
I thought (could be wrong, and instead I'm thinking of SVN) that our latest 3.30 release of ULX corrected issues where this could occur.
nerdygamer
« Reply #7 on: February 16, 2008, 01:37:07 pm »
i run 3.31 beta from the svn i think. but no the 3.30 version dose not fix the problem :-\
