Author Topic: Problem with ULX...  (Read 4209 times)
Offline FoxboyJT
Problem with ULX...
« on: February 12, 2008, 11:21:30 pm »
Allright, well, after the GMod 2008 update, I was a little dismayed at the fact my server had problems with all mods. NO prob, I waited tlil the new stuff came out. But after many attempts, ULX is giving me the largest issue. I normaly run a listen server for my friends, so from what I've read, with a default install it should have no issues.I installed it to the right directory (I checked each time). When I try using the menu command, it says "ulx" is an unrecognized command. Help? ^^;
Nevermind....
« Last Edit: February 12, 2008, 11:24:44 pm by FoxboyJT »
