Author Topic: Mysql  (Read 25975 times)
Offline ben build
Mysql
« on: February 15, 2008, 05:12:59 pm »
This is quite a big request but would it be possible to have a mysql option which makes it use mysql for users, groups and bans instead of txt
I run multiple servers and i don't want to have to write my own admins system to accommodate this, I know there is the uban system but it doesn't seem to integrate very well.
Offline spbogie
Re: Mysql
« Reply #1 on: February 18, 2008, 08:21:00 am »
There is no need to write an entirely new admin mod just to get your users through SQL. You can just write a module for ULib and call ULib.ucl.addUser and ULib.ucl.addGroup. Full documentation of the ULib developer library can be found at http://www.ulyssesmod.net/docs.
One small note on making it a module however, you should only put a small init script in lua/ULib/modules/ as it will be run on both client and server. Put all the functionality and configuration in (a) separate file(s) located elsewhere.
I do not personally have the time right now to create this myself (finals and such), and I know Megiddo and JamminR have been quite busy lately as well, but we encourage you, or anyone else, to attempt. We wrote ULib for everyone, not just us, to use. If you take up this project, we would greatly appreciate it if you would release it here. If you can't/don't want to try this, and no one else picks it up, you will have to wait until we have time.
Re: Mysql
« Reply #2 on: February 18, 2008, 12:08:21 pm »
We're pulling the users for all our servers from these forums with just a few lines of code. :)
Re: Mysql
« Reply #3 on: February 18, 2008, 03:18:22 pm »
I personally don't know SQL, but as spbogie said, don't have time to learn either.
Megiddo, mind sharing those few lines of code for pulling from our db, minus PW and servernames/etc. Or would that open us to risk?
I've always been curious what it looks like. Might help Ben on his way.
Ben,
As for UBan, Other than it using different commands, why would it be more difficult than what you wish now?
Re: Mysql
« Reply #4 on: February 18, 2008, 05:37:24 pm »
Obviously this only works for SMF forums, but maybe it will help you. The grants is based off the group IDs assigned by the forums. This is more than my previously stated few lines of code because of the MySQL wrapper, which was grabbed from UBan (and not really entirely necessary). The only function of substance is CheckUser().
--     Config     --
local host = "localhost"
local username = "secretuser"
local password = "secretpass"
local database = "ulyssesmod_forums"
local port = 3306
local prefix = "smf2_" -- table prefix
local grants =
[9] = "superadmin",
[10] = "donator",
[2] = "superadmin",
[11] = "donatoradmin",
[13] = "admin",
local persistent = false -- Use a persistent MySQL connection?
Table structure:
<prefix>themes
ID_MEMBER, ID_THEME, variable, value (1, 1, steamid, STEAM_****)
<prefix>members
ID_MEMBER, memberName, ID_GROUP (1, megiddo, 9)
9 = developer
10 = donator
2 = global mod
require( "mysql" )
module( "forumusers", package.seeall )
local db
function DoQuery( query, type )
local result, isok, err = mysql.query( db, query, type or mysql.QUERY_NUMERIC )
if not isok and err == "" then isok = true end -- False positive
if not isok then
error( tostring( err ), 2 )
return nil
if result then
-- print( query ) -- For debug
-- PrintTable( result )
return result
function Connect()
if db then return db end -- Still connected
db, err = mysql.connect( host, username, password, database, port )
if db == 0 then
db = nil
error( tostring( err ), 1 )
return
return db
function Disconnect( force )
if not db then return end -- Already disconnected
if persistent and not force then return end -- Don't disconnect, persistent
local succ, err = mysql.disconnect( db )
if not succ then
db = nil
hook.Add( "ShutDown", "ForumUsersClose", function() Disconnect( true ) end ) -- Force closed on shutdown.
function Escape( str )
if not db then
Msg( "Not connected to DB.\n" )
return
if not str then return end
local esc, err = mysql.escape( db, str )
if not esc then
return nil
-- print( "esc=" .. esc ) -- For debug
return esc
-- Check a user
function CheckUser( ply )
Connect()
ULib.ucl.authed[ ply ] = nil
ULib.ucl.awaitingauth[ ply ] = nil
local results = DoQuery( "SELECT ID_MEMBER FROM " .. prefix .. "themes WHERE value=\"" .. ply:SteamID() .. "\"" ) -- Get memberids with this steamid
if results[ 1 ] then -- Get into the row. I realize we're not handling cases where multiple users have the same steamid but meh. Should never happen, right?
local uid = results[ 1 ][ 1 ] -- Member ID
local results = DoQuery( "SELECT memberName, ID_GROUP FROM " .. prefix .. "members WHERE ID_MEMBER=" .. uid ) -- Get name and group
if results[ 1 ] and grants[ tonumber( results[ 1 ][ 2 ] ) ] then -- Should always exist but might as always make sure. Also make sure they have a permission
local name = results[ 1 ][ 1 ]
local group = grants[ tonumber( results[ 1 ][ 2 ] ) ]
ULib.ucl.addUser( name, "steamid", ply:SteamID(), { group } )
ULib.ucl.probe( ply ) -- If they weren't added above add them now
Disconnect()
hook.Add( "PlayerInitialSpawn", "ForumUsersInitSpawn", CheckUser )
hook.Remove( "PlayerInitialSpawn", "ucl_initialspawn" ) -- We'll handle calling ucl.probe ourself
« Last Edit: February 18, 2008, 05:39:56 pm by Megiddo »
Offline high6
Re: Mysql
« Reply #5 on: February 18, 2008, 10:03:20 pm »
I am actually working on making ulx mostly sql for my friends server. I will make it so it is easy to integrate with new version.
*wishes for ulx callbacks*
Offline spbogie
Re: Mysql
« Reply #6 on: February 18, 2008, 10:52:35 pm »
Callbacks for what?
Offline high6
Re: Mysql
« Reply #7 on: February 18, 2008, 10:58:19 pm »
Callbacks for what?
like
ulx.AddBanFunction(func_here)
function func_here()
//called when a person is banned.
so other mods can be integrated into ulx really easy and hook its bannings.
Re: Mysql
« Reply #8 on: February 18, 2008, 11:32:53 pm »
Why do you not just add them yourself?
Offline spbogie
Re: Mysql
« Reply #9 on: February 19, 2008, 07:57:25 am »
For your purpose you would want to overried the functionality anyways. If you want everything to be over on SQL then it is probably best to override the underlying ULib functions instead, directing all bans done through ulib to your SQL server, and leaving ULX unmodified.
Offline high6
Re: Mysql
« Reply #10 on: February 19, 2008, 10:19:27 am »
ok well I will try to get this done soon as possible. Problem is though that mysql broke for the latest gmod. So either I have to wait or attempt to rebuild it myself... Never was good with gmod dlls.
Offline spbogie
Re: Mysql
« Reply #11 on: February 19, 2008, 11:06:15 am »
dlls will no longer work from the addons directory, other than that, the sql module should work fine. You just need to move it out of addons and put it in the main /lua/includes/modules.
Offline high6
Re: Mysql
« Reply #12 on: February 19, 2008, 11:14:47 am »
ok well I am trying to figure out whats wrong with it, hopefully i get it working soon. :D.
Re: Mysql
« Reply #13 on: April 08, 2010, 05:55:11 pm »
Incidentally, after two years, this request got filled! See here.
Offline Frrz
    • Youtube ftw
Re: Mysql
« Reply #14 on: April 09, 2010, 01:07:44 pm »
You bumped a two year old thread?
