Author Topic: can ulx advertize in my server  (Read 5953 times)
Nerdygamer
« on: February 17, 2008, 07:17:44 pm »
Is there a code in ulx that every 10 mins is says stuff in the middle of the screen?
Re: can ulx advertize in my server
« Reply #1 on: February 17, 2008, 07:44:14 pm »
Good question. I'm surprised we don't have it mentioned in our ulx_readme.txt file.
Copy the /addons/ulx/cfg to your gmod/ root.. Answer yes to when it asks about cfg folder already existing.
Once that's done, go into gmod/cfg/server.ini - that is ULX's ini file, not to be confused with server.CFG, which is Source server settings file.
Once in server.ini, you'll see all the various things you can add/edit/set up on server start/map change.
Additional tip.. if you have special items you want set for special maps, see /gmod/cfg/maps and create a <mapname>.ini
If you only want it to advertise until next map change/server restart, see "ulx help". I think the command is "ulx addCadvert". Don't hold me to that.
« Last Edit: February 17, 2008, 07:48:54 pm by JamminR »
« Reply #2 on: February 17, 2008, 07:46:49 pm »
It is in the readme JamminR, the problem is that no one ever reads it.
« Reply #3 on: February 17, 2008, 07:49:21 pm »
I just searched the readme for server.ini ... didn't find it
[EDIT]
From the readme
"Check out the configs folder in ulx for some more goodies."
However, 95% of server hosts have no idea where that is, because they never read any server tutorial
« Last Edit: February 17, 2008, 07:51:17 pm by JamminR »
Nerdygamer
« Reply #4 on: February 17, 2008, 09:46:51 pm »
WOW now i ****. how do i get rid of the advert? PLZ HURRY! :'(
« Last Edit: February 17, 2008, 10:46:12 pm by Megiddo »
nerdygamer
« Reply #5 on: February 17, 2008, 10:00:56 pm »
nvm i fixed it! ;D
Offline Avien
« Reply #6 on: February 18, 2008, 07:24:25 pm »
So i am assuming that by copying the cfg to the main gmod folder that ulx will use this before the other folder?  I have added my uppl settings to the ulx/cfg/server.ini and by copying it to the gmod/cfg/ then it will be save from updates and will be used instead of the other file?
« Reply #7 on: February 18, 2008, 08:22:33 pm »
exactly.
It checks all of the top level folders first.
eg.
root/motd.txt
cfg/server.ini
That way when you update ULX you wont have to worry about these files being overridden by the update.
« Reply #8 on: February 18, 2008, 08:23:49 pm »
And as far as I know, this is true of just about any addon config file, since the addons files are 'virtual'.
