Author Topic: !stopsound  (Read 18128 times)
Offline Bloodclaw
!stopsound
« on: February 22, 2008, 11:08:13 am »
Hi!
Could it be possible to do a !stopsound command, so it does exactly the same thing as when we type "stopsound" in console, except that it does not need sv_cheats 1 ?
I often still have burning sounds after burning objects / igniting players, and I don't want to activate cheats.
Offline high6
Re: !stopsound
« Reply #1 on: February 22, 2008, 01:11:18 pm »
stopsounds doesn't need sv_cheats 1.
Re: !stopsound
« Reply #2 on: February 22, 2008, 01:39:27 pm »
Listen to this person. :)
Re: !stopsound
« Reply #3 on: February 22, 2008, 07:21:34 pm »
And just so there isn't confusion, let me make sure this is clear. (I've seen the debate so many times because the detail is in the S)
You must use plural 'stopsounds' in console.
No S does require sv_cheats.
That being said ... his suggestion might have some merit, but not for the reason he states.
I used ulx playsound to play a sound to a server the other night.
The sound, played in Source games, loops. I didn't know this (It's title didn't have 'loop' as so many of the sound titles do)
It continued looping until I and the clients used stopsounds in console.
Perhaps a ulx stopsounds wouldn't be a bad idea after all.
Offline Bloodclaw
Re: !stopsound
« Reply #4 on: February 23, 2008, 02:08:53 am »
stopsound (no S) need sv_cheats 1  :P
It's a dedicated server screen, ok but I type that in my console too :
Offline high6
Re: !stopsound
« Reply #5 on: February 23, 2008, 06:57:22 am »
stopsounds is a gmod client command, dedicated server doesn't have because it has no use for it.
Offline Bloodclaw
Re: !stopsound
« Reply #6 on: February 23, 2008, 07:46:59 am »
We're both right  :D
stopsounds stop all sounds.
stopsound stop all sounds and tell you what sounds (filepath) it stopped.
You thought it didn't need that because you just played singleplayer / created a listenserver. It's not the case of dedicated servers.
Offline high6
Re: !stopsound
« Reply #7 on: February 23, 2008, 12:26:12 pm »
stopsounds does not need sv_cheats 1.
Do you want a freaking video?
Offline benbrooks
Re: !stopsound
« Reply #8 on: February 23, 2008, 12:42:24 pm »
ulx cexec <all> stopsounds
Simple.
Offline Bloodclaw
Re: !stopsound
« Reply #9 on: February 23, 2008, 01:24:32 pm »
I thought it does, but you're right.
(Commands are confusing me  :P )
