Author Topic: ULib usermessage bug ?  (Read 7450 times)
Offline Chironex
  • Formerly known as Kyzer
« on: February 29, 2008, 10:13:20 am »
Hello all, I'm using a usermessage, this is the part on the client:
local wtsa_keywords_string_cl = ""
local function WTSA_Save_Keywords_CL( wtsa_usermessage )
    local wtsa_usermessage_string = wtsa_usermessage:ReadString()
    if wtsa_usermessage_string != "ULib_autocomplete" then
        if wtsa_usermessage_string != "WTSA_UMSG_END" then
            wtsa_keywords_string_cl = wtsa_keywords_string_cl .. wtsa_usermessage_string
            WTSA_Debug("wtsa_keywords_string_cl = \n" .. wtsa_keywords_string_cl )
            WTSA_Debug("writing\n" .. wtsa_keywords_string_cl .."in file..")
            file.Write("wtsa_keywords.txt", wtsa_keywords_string_cl)
usermessage.Hook( "wtsa_save_keywords_um", WTSA_Save_Keywords_CL )
Notice the line: if wtsa_usermessage_string != "ULib_autocomplete" then
I needed to do that because for an unknow reason, i retrieve this string each time i use my usermessage :/
By that i mean that: WTSA_Debug("wtsa_keywords_string_cl = \n" .. wtsa_keywords_string_cl )
will print:
wtsa_keywords_string_cl = ULib_autocompleteif i don't put that IF statement.
Any idea why?
Here is the server part as well, if needed:
function WTSA_Save_Keywords_SV(ply)
    local plyid = ply:UniqueID() -- foutre ca apres if()
    if ply and ply:IsPlayer() and PlayerCustomsKeywords[plyid] != nil then
        local wtsa_keywords_string_sv = ""
        local RF = RecipientFilter()
        RF:AddPlayer( ply )
        for k, v in pairs(PlayerCustomsKeywords[plyid]) do
            wtsa_keywords_string_sv = k .. "=" .. v .. "\n"
            umsg.Start( "wtsa_save_keywords_um", RF)
                umsg.String(wtsa_keywords_string_sv)
            umsg.End()
            umsg.String("WTSA_UMSG_END")
        umsg.End()
        WTSA_Debug(ply:Nick() .. "'s keywords are saved.")
concommand.Add("wtsa_savekeywords", WTSA_Save_Keywords_SV)
I don't think i do something wrong, i believe this is because i use it in a concommand..?
Also, while i posted this code..any idea how to make it more efficient ? I'm not satisfied, all that to save a table from server to a client file, 1 line = 1 usermessage..what is umsg.PoolString, should i use that?
Thanks for helping me :D
« Last Edit: February 29, 2008, 10:40:11 am by Kyzer »
Re: ULib usermessage bug ?
« Reply #1 on: March 04, 2008, 04:13:16 pm »
Kyzer, did you ever resolve this issue?
Offline Chironex
« Reply #2 on: March 04, 2008, 10:14:27 pm »
Nope, as i said i used this workaoround:
There is nothing else i can do from my script :s
Offline spbogie
« Reply #3 on: March 04, 2008, 11:12:14 pm »
Hmmm, first thought is that somewhere umsg.End() isn't being called. I've double checked, and all usermessages in both ULib and ULX are properly ended.
