Author Topic: Allways allow prop spawn for admins?  (Read 4817 times)
Offline CrazySwede
« on: April 01, 2008, 08:23:58 am »
Is it possible to make the propspawn restrictions not affect the admins on my server somehow?
Is it also possible to remove the messages that shows up in chat when I change any settings so only I see that?
Or is it possibly allready like that? ???
Re: Allways allow prop spawn for admins?
« Reply #1 on: April 01, 2008, 01:16:53 pm »
Are you refering to UPPL?
« Reply #2 on: April 01, 2008, 03:59:46 pm »
Not unless you're using Uppl (see releases section).
Not with sbox_ and sv_blah variables. They're controlled by a Source engine message that I'm (95%) sure can't be blocked.
As for any other changes, admin logging of commands, see your /addons/ulx/cfg/server.ini ... if you change any settings there, save it in /gmod/cfg, or it will get overwritten next time you update the addon.
By default, most ULX commands run from game console (instead of the menu) will show (silent) to admins only.
Offline CrazySwede
« Reply #3 on: April 02, 2008, 06:57:54 am »
Thankyou very much!
The problem is now solved!
