Author Topic: Help with Admin Menu  (Read 4546 times)
Offline Typo001
    • My (Personal) Site
« on: April 03, 2008, 04:37:03 pm »
There is a part of the admin menu that does not work; I can not change the Global God mode, PvP damage, Limited Phisgun, or Noclip. Every time I click on it gives me some error. And it will not let me change it though settings. So I am stuck in god mode on my servers. Thanks!
Re: Help with Admin Menu
« Reply #1 on: April 03, 2008, 04:44:27 pm »
ULX just makes use of preexisting con_variables for these things.
physgun_limited <1/0>
sbox_noclip <1/0>
sbox_plpldamage <1/0>
sbox_godmode <1/0>
Type those in console (dedicated console.. or with rcon) to change them manually. If you are running a listen server, you can type them in your console.
Other than that, are you running the latest SVN? Because this error was fixed as far as I know, and works fine with the latest version of the SVN.
Offline Typo001
« Reply #2 on: April 03, 2008, 05:14:47 pm »
Thanks for the variables I could not remember what they were, but about myself getting the latest version, I should, I mean I just got Ulx little over a month ago, and at first it was working but I do not know if I edited something wrong or a update or even I downloaded something and it interferes with it I am not sure completely. But thanks for the variables again.
Offline MathieuG89
« Reply #3 on: April 03, 2008, 07:37:08 pm »
That is indeed strange, it started to do this on my server also, changing map seems to fix it.
