Author Topic: uTeam Doesn't Work on our server  (Read 11563 times)
Offline lyoko
« on: April 07, 2008, 09:52:07 am »
Its uTeam 1.12 and i tried infinite times to reupload it and it doesn't work. players keeping to be unassigned team.
please help me
« Last Edit: April 10, 2008, 07:29:31 am by lyoko »
Re: uTeam Doesn't Work on my server
« Reply #1 on: April 07, 2008, 12:00:17 pm »
Sounds like incorrect configuration
Offline lyoko
« Reply #2 on: April 07, 2008, 12:59:12 pm »
i use the default.
« Reply #3 on: April 07, 2008, 02:01:11 pm »
Did you put the config in the data directory as instructed?
« Reply #4 on: April 07, 2008, 02:24:55 pm »
UTeam.lua goes in garrysmod/lua/autorun
UTeam.txt goes in garrysmod/data
Make sure you only edit UTeam.txt and set it up so that it uses the same groups as you have ULX set to use. CaSe Is ImPoRtAnT. Admin and admin are COMPLETELY different.
Offline lyoko
« Reply #5 on: April 08, 2008, 05:13:36 am »
yes. its still doesn't work.
Offline spbogie
« Reply #6 on: April 08, 2008, 08:48:11 pm »
Please post the output of both
lua_run PrintTable( UTeam.teams ) and
lua_run PrintTable( ULib.ucl.authed ) from SERVER console or RCON (not "ulx rcon"), while you and others are connected.
(see the FAQs for how to copy text from the console if you're running dedicated from your own box)
Offline lyoko
« Reply #7 on: April 09, 2008, 10:00:08 am »
first
] rcon lua_run PrintTable( UTeam.teams )
> PrintTable ( UTeam.teams )...
1:
      name   =   SuperAdmins
      group   =   superadmin
      armor   =   1000
      color:
            a   =   255
            r   =   0
            g   =   200
            b   =   85
      hp   =   1000
      plytable:
            1   =   SprintSpeed:1000
            2   =   WalkSpeed:500
2:
      name   =   Admins
      armor   =   500
      color:
            a   =   255
            r   =   255
            g   =   50
            b   =   50
      hp   =   500
      group   =   admin
3:
      name   =   Operators
      armor   =   200
      color:
            a   =   255
            r   =   255
            g   =   200
            b   =   0
      hp   =   200
      group   =   operator
4:
      group   =   user
      color:
            a   =   255
            r   =   0
            g   =   100
            b   =   255
      name   =   Players
      model   =   male1
second
> PrintTable ( ULib.ucl.authed )...
Player [NULL]:
type = guest
groups:
1 = user
2 = user
id =
account = CoolDog
acl:
allow:
deny:
uniqueid = 548117733
Player [2][DeathGod -Gray Fox-]:
deny:
type = steamid
groups:
1 = admin
2 = user
account = deathgod
id = STEAM_0:0:83760
allow:
uniqueid = 212486424
Player [NULL]:
type = guest
groups:
1 = user
2 = user
id =
account = vodka
acl:
allow:
deny:
uniqueid = 267620353
Player [NULL]:
type = guest
groups:
1 = user
2 = user
id =
account = CoolDog
acl:
allow:
deny:
Player [NULL]:
type = guest
groups:
1 = user
2 = user
id =
account = vodka
acl:
allow:
deny:
Player [NULL]:
deny:
type = steamid
groups:
1 = superadmin
2 = 0
account = lyuki
id = STEAM_0:1:16168284
allow:
uniqueid = 1018692475
Player [NULL]:
deny:
type = steamid
groups:
1 = superadmin
2 = 0
account = lyuki
allow:
Player [NULL]:
deny:
type = steamid
groups:
1 = admin
2 = user
account = deathgod
allow:
Player [NULL]:
type = guest
groups:
1 = user
2 = user
id =
account = CoolDog
acl:
allow:
deny:
« Last Edit: April 09, 2008, 10:11:06 am by lyoko »
« Reply #8 on: April 09, 2008, 11:30:51 am »
Are you using the sui scoreboard?
Offline lyoko
« Reply #9 on: April 09, 2008, 12:41:04 pm »
yes. i'm using the newest i found here.
Offline spbogie
« Reply #10 on: April 09, 2008, 12:57:18 pm »
Ok, with multiple people on the server get the output from
lua_run for _, v in pairs( player.GetAll() ) do print( v, v:Team(), team.GetName( v:Team() ) ) end
Also check both cilent and server console for any errors (while loading and when a player is connecting/spawning are the key points to look around).
Offline lyoko
Re: uTeam Doesn't Work on our server
« Reply #11 on: April 10, 2008, 07:31:42 am »
 rcon lua_run for _, v in pairs( player.GetAll() ) do print( v, v:Team(), team.GetName( v:Team() ) ) end
autokick is disabled for Lyoko
> for _, v in pairs ( player.GetAll ( ) ) do print ( v, v : Team ( ) , team.GetName ( v : Team ( ) ) ) end...
Player [1][vodka]   1001   Unassigned
Player [2][CoolDog]   1001   Unassigned
Player [3][sysRq<marshmallow>]   1001   Unassigned
Player [6][Lyoko]   1001   Unassigned
i can't get to the server console
Offline lyoko
« Reply #12 on: April 11, 2008, 08:53:20 am »
No solution?
Offline blacksythe
« Reply #13 on: April 15, 2008, 02:09:51 pm »
By the looks of it your problem resides here
2:
      name   =   Admins
                                 <----------------- Correct position
      armor   =   500
      color:
            a   =   255
            r   =   255
            g   =   50
            b   =   50
      hp   =   500
      group   =   admin  <------------ Incorrect position
Ditto for all of the others
4:
                             <----------------Correct
      group   =   user
      color:
            a   =   255
            r   =   0
            g   =   100
            b   =   255
      name   =   Players <------------------ Incorrect
      model   =   male1
Alter this in uteam.txt
correct me if i'm wrong mind you
« Reply #14 on: April 15, 2008, 05:21:54 pm »
Blacksythe, though I don't know how to fix lyoko's problem, and your answer could be helpful, Lua (and Garry's and or our) functions involving printing of tables are often known to display out of order.
Though if his Uteam.txt file does look like that it would be wrong, it's very likely the print out he gave is just the table display oddity.
