Author Topic: Admin sounds, tools and other code chat.  (Read 95065 times)
Re: Admin sounds, tools and other code chat.
« Reply #150 on: June 02, 2008, 01:38:23 am »
Adding more to the script from above, I'm trying to have server promotions based on the players total time in the server while they have not had a warning lvl.
Players_Time.txt:
"players"
"STEAM_0:1:13630765"
"time"
"0"
Promotions.lua:
  1. Promotion_Inerval = 2 // Time in hours
  2. Time_Reduction = 10 // Time lost in minutes per warning level
  3.
  4.
  5. Player_Time_Table = (ULib.parseKeyValues( file.Read("Player_Times.txt")))
  6.
  7.
  8. function PromotionInit( ply )
  9.         timer.Create( ply:Nick().. "Promotion_Timer", 1, 0, SetTime, ply)
  10.         ply.Last_Check = 0
  11.                 for _, Id in pairs(Player_Time_Table.players) do
  12.                         if string.find( Id, ply:SteamID(), 1, true) then
  13.                                 ply.total_time = Player_Time_Table.players.ply:SteamID().time
  14.                         else
  15.                                 ply.total_time = 0
  16.                         end
  17.                 end
  18. end
  19. hook.Add( "PlayerInitialSpawn", "PromotionInit_Hook", PromotionInit )
  20.
  21. function SetTime( ply )
  22.         ply.total_time = (ply.total_time + 1)
  23.         table.insert( Player_Time_Table.players.ply:SteamID().time, 1, ply.total_time)
  24.         file.Write( "Player_Times.txt", ULib.makeKeyValues(Players_Time_Table))
  25. end
  26.
  27.
  28. function Warn_Think()
  29.         for _, ply in pairs( player.GetAll() ) do
  30.                 if ply.warn > 0 then
  31.                         if timer.IsTimer( ply:Nick().. "Promotion_Timer" ) then
  32.                                 timer.Stop( ply:Nick().. "Promotion_Timer" )
  33.                         end
  34.                 else
  35.                         if timer.IsTimer( ply:Nick().. "Promotion_Timer" ) then
  36.                                 timer.Start( ply:Nick().. "Promotion_Timer" )
  37.                         end
  38.                 end
  39.                 if (ply.warn > 5) and (!ply.warn == ply.Last_Check) then
  40.                         if (!ply.total_time == 0) then
  41.                                 ply.total_time = (ply.total_time - (ply.warn * Time_Reduction))
  42.                                 ply.Last_Check = ply.warn
  43.                                         if ply.total_time < 0 then
  44.                                                 ply.total_time = 0
  45.                                         end
  46.                         end
  47.                 end
  48.         end
  49. end
  50. timer.Create( "ThinkTimer_Warn", 1, 0, Warn_Think)
Error:
Timer Error: ULib/modules/Promotions.lua:22: attempt to perform arithmetic on fi
eld 'total_time' (a nil value)
That's with me in the server, I realize I didn't add the PlayerDisconnected hook to Destroy the timer yet.
Um... Warn_Think is working as it should, but the total_time isn't getting set, and I need that inorder to go any further in this script. I don't see anything wrong, but I've been know to miss the little to medium problems :S.
« Reply #151 on: June 02, 2008, 11:49:20 pm »
Ok, wow. There were alot of errors in that last script, so here's the new one.
Promotions.lua:
  1. Player_Time_Table = (ULib.parseKeyValues( file.Read("Player_Times.txt")))
  2. Msg("Table Created and set \n")
  3.
  4. function PromotionInit( ply )
  6.         ply.Last_Check = 0
  7.                 for _, Id in pairs(Player_Time_Table.players) do
  8.                         if string.find( Id, ply:Nick(), 1, true) then
  9.
  10.                         else
  11.                                 Player_Time_Table.players.ply:Nick() = {}
  12.                                 Player_Time_Table.players.ply:Nick().time = 0
  13.                         end
  14.                 end
  15. end
  16. hook.Add( "PlayerInitialSpawn", "PromotionInit_Hook", PromotionInit )
Player_Times.txt:
"players"
"Jay209015"
"time" 20
"TestPlayer"
"time" 0
Jay209015 was entered straight into the text file by me, but test players was entered in with:
lua_run Player_Time_Table.players.TestPlayer = {}
lua_run Player_Time_Table.players.TestPlayer.time = 0
in that order. After the server starts Player_Time_Table = nil for somereason, even if the tables are in the text file.
> PrintTable(Player_Time_Table)...
includes\util.lua:21: bad argument #1 to 'pairs' (table expected, got nil)
==EDIT==
More to the errors list:
ULib/modules/Promotions.lua:14: unexpected symbol near '='
-- Error SENDING CLIENTSIDE file -------------------------
- File: ULib/modules/Promotions.lua
« Last Edit: June 03, 2008, 12:57:13 am by jay209015 »
« Reply #152 on: June 03, 2008, 02:04:54 am »
  3.
  5.         ply.Last_Check = 0
  6.                 if !(util.tobool(Player_Time_Table.playersJay209015.time)) then
  7.                         Player_Time_Table.players.Jay209015 = { time = 0}
  8.                 end
  9.                 timer.Create(ply:Nick().. "Promotion_Timer", 1, 0, SetTime, ply)
  10. end
  11. hook.Add( "PlayerInitialSpawn", "PromotionInit_Hook", PromotionInit )
  12.
  13. function SetTime( ply )
  14.         Player_Time_Table.players.Jay209015.time = Player_Time_Table.players.Jay209015.time + 1
  15.         file.Write( "Player_Times.txt", ULib.makeKeyValues(Player_Time_Table))
  16. end
Above works fine, but below does not.
  3.
  6.                 if !(util.tobool(Player_Time_Table.players.ply:Nick().time)) then
  7.                         Player_Time_Table.players.ply:Nick() = { time = 0}
  8.                 end
  10. end
  12.
  14.         Player_Time_Table.players.ply:Nick().time = Player_Time_Table.players.ply:Nick().time + 1
  16. end
Server side error:
ULib/modules/Promotions.lua:11: unexpected symbol near '='
Client side error:
ULib/_cl_2.20/misc.lua:38: bad argument #1 to 'gsub' (string expected, got nil)
is there something else I can use other than ply:Nick() to get the players name and have it work in a table?
« Reply #153 on: June 03, 2008, 06:33:41 pm »
Ok, after a bit of research I fixed the problem from above, but the new one is confusing.
All was good until my server was completely restarted. Now it does something really wierd.
Player_Time.txt:
"players"
"TestPlayer"
"time" 0
lua_run PrintTable(Player_Time_Table):
???^*#1:
                TestPlayer:
                                time    =       0
Code that rights this table.
verification table was set:
[ULIB] Loading module: Promotions.lua
Only error reported:
ERROR: Hook 'PromotionInit_Hook' Failed: ULib/modules/Promotions.lua:13: attempt
 to index field 'players' (a nil value)
Removing Hook 'PromotionInit_Hook'
Function of the hook mentioned above:
  1. function PromotionInit( ply )
  2.         ply.Last_Check = 0
  3.                 if Player_Time_Table.players[ply:Nick()] == nil then
  4.                         Player_Time_Table.players[ply:Nick()] = { time = 0 }
  5.                 end
  6.                 if !ply:IsAdmin() and !ply:IsSuperAdmin() then
  7.                         if ply:IsUserGroup( "user" ) then
  8.                                 ply.promotionlvl = 0
  9.                         else
  10.                                 if ply:IsUserGroup( "mod" ) then
  11.                                         ply.promotionlvl = 1
  12.                                 else
  13.                                         if ply:IsUserGroup( "respected" ) then
  14.                                                 ply.promotionlvl = 2
  15.                                         else
  16.                                                 if ply:IsUserGroup( "operator" ) then
  17.                                                         ply.promotionlvl = 3
  18.                                                 end
  19.                                         end
  20.                                 end
  21.                         end
  22.                 end
  23.                 timer.Create(ply:Nick().. "Promotion_Timer", 1, 0, SetTime, ply)
  24. end
  25. hook.Add( "PlayerInitialSpawn", "PromotionInit_Hook", PromotionInit )
It's obvious why the hook is broken, but not the reason that the "players" changes to "???^*#1" this is the wierdest errors I've seen so far. Any suggestions/idea on how to fix or as to why this is happening?
==EDIT==
Got this error on client:
Client side error:
[code]
[/code]
Line 38 from the error above:
str = string.gsub( str, ULib.makePatternSafe( comment ) .. "[%S \t]*", "" )
« Last Edit: June 03, 2008, 06:42:19 pm by jay209015 »
