Author Topic: ULib freezing my dedicated server  (Read 6128 times)
Offline Patrik
« on: April 15, 2008, 03:28:48 am »
I got a very annoying problem, when I try to start my dedicated server with ULib (and ULX) it freezes in the loading of ULib. I tried with ULib SVN, 2.20 and 2.10 but it still freezes. I also got Wire, Tiled Model Pack and PHX on the server. I didn't change anything, this just happened suddenly after a server crash. The server works fine without ULib (and ULX then)
I took this screenshot of the server console when it happened:
I tried to wait 20 minutes but it stays like that.
Re: ULib freezing my dedicated server
« Reply #1 on: April 15, 2008, 10:50:08 am »
That is odd. I can assure you that you are the first case of this I have heard of.
« Reply #2 on: April 15, 2008, 03:25:04 pm »
Indeed. Try removing all other addons (including ULX) and loading with ONLY ULib and load it on gm_construct.
« Reply #3 on: April 15, 2008, 05:16:16 pm »
If it still doesn't start with all other addons removed, go into your gmod/data folder, and delete misc_registered.txt
If that doesn't work, rename your gmod/data/ULib folder to BackupULib or something like that, then try restart.
If it works, your data files for ULib got corrupted during the crash, and you'll probably have to rebuild them.
Offline Patrik
« Reply #4 on: April 16, 2008, 06:29:16 am »
Thanks for your help guys, after renaming the ULib folder everything worked fine again!  ;D
Offline Pugnacious
« Reply #5 on: April 16, 2008, 12:14:20 pm »
It does this for me on a fresh install of ulx/ulib and it's always done that on just about any server i've seen.
