Author Topic: RFC: Common Prop Protection Interface (CPPI)  (Read 13 times)
« on: April 16, 2008, 02:52:43 pm »
:siren: Note that this is a WIP (Work in Progress). Feel free to start implementing this in your prop protection, but we are seeking feedback before we submit a final standard.:siren:
[highlight]Purpose of CPPI: Define a standard interface for prop protectors to use for easy third-party integration with any prop protector. I realize this is a long shot, but I don't think anyone has tried something like this within the gmod community to date, so I suppose it's worth a shot.[/highlight]
Now onto the standard:
[highlight]Namespace: CPPI (store these in the global table 'CPPI')[/highlight]
Function: GetName()
  • Returns the name of the active prop protection (IE, "Amazing Prop Sprite")
  • Return value constraints: String, less than 255 characters
  • Both client and server side.
Function: GetDate()
  • Returns the Unix time stamp of the date/time this was released (IE '1199142000' for January 1, 2008. See os.time() or http://soft.zoneo.net/Unixtime/index.php to generate the time).
  • Return value constraints: Number
  • Use UTC time.
Function: GetVersion()
  • Returns the version of the active prop protection (IE, "1.0" or "1.5.6a rev258")
Function: GetFriends( ply )
  • Returns the friends of a player, other players allowed to manipulate the specified players objects.
  • Ply argument: A valid player object.
  • Return value constraints: Table, less than 64 elements
  • Hint: If your prop protection does not implement such a feature, return an empty table.
  • Both client and server side, but client side is only required to implement this function for the local player.
Function: GetInterfaceVersion()
  • Returns the version of the interface (the version of this standard that the interface is using)
  • Return value constraints: returns the number 1
Function: NameFromUID( uid )
  • Returns the name of the player that was using that UID (ply:GetUniqueID())
  • uid will be a number specifying a UID (but do error checking regardless)
  • Return value constraints: String of player name less than 32 characters, or nil.
  • Both client and server side, only required to function on the local player's UID client-side.
[highlight]Namespace: Entity (the entity metatable)[/highlight]
Function: CPPIGetOwner()
  • Returns the owner of this entity
  • Returns the player object that owns this entity first and the UID (ply:GetUniqueID()) second. Both values should be nil if no one owns it, first value should be nil if the player is disconnected.
  • Must function on both the server and client side for any entity.
Function: CPPISetOwner( ply )
  • Sets a new owner for this entity
  • Returns true on success, false on failure
  • ply will be a player entity (do error checking regardless)
  • ONLY on server
Function: CPPISetOwnerUID( uid )
  • uid will be a uid for a player (do error checking regardless)
  • ONLY on server
Function: CPPICanTool( ply, toolmode )
  • Checks if a player can tool this object with specified tool. This function MUST NOT reassign ownership; that the player will actually use the tool is not guaranteed.
  • Returns true if they can, false if they can't.
  • toolmode will be a string specifying the tool mode to check. May not be one of the default GMod tools.
  • Hint: This should be a close alias of your CanTool hook
  • ONLY on server
Function: CPPICanPhysgun( ply )
  • Checks if a player can physgun this object. This function MUST NOT reassign ownership; that the player will actually use the physgun is not guaranteed.
  • Hint: This should be a close alias of your PhysgunPickup hook
  • ONLY on server
Function: CPPICanPickup( ply )
  • Checks if a player can pick up this object with '+use' or the gravgun. This function MUST NOT reassign ownership; that the player will actually pick up the object is not guaranteed.
  • Hint: This should be a close alias of your GravGunPickupAllowed hook
  • ONLY on server
Function: CPPICanPunt( ply )
  • Checks if a player can punt this object with the gravgun. This function MUST NOT reassign ownership; that the player will actually punt the object is not guaranteed.
  • Hint: This should be a close alias of your GravGunPunt hook
  • ONLY on server
[highlight]Namespace: Hooks (normal gamemode hooks called using gamemode.Call() and hooked using hook.Add())[/highlight]
Function: CPPIAssignOwnership( ply, ent )
  • Called when ply assumes ownership of ent.
  • If the hook is blocked (by returning true or false), ownership should not be assigned.
  • ply should be a valid player entity assuming the ownership or nil if removing ownership
  • ent should be a valid entity that the ply now owns
  • Hint: This should be called both after a player spawns a new ent and when ownership is reassigned
  • Only required on the server, but preferred on client as well.
Function: CPPIFriendsChanged( ply, newfrends )
  • Called when ply gains or loses friends (other players who are allowed access to their ents).
  • Should be called after friends are re-assigned, cannot be blocked.
  • ply should be a valid player entity that had their friends changed
  • newfriends should be a table containing the player's friends.
  • Hint: This should be called both after a player spawns in the server and when their friends change
  • Only required on the server, but preferred on client as well (at least for local player).
« Last Edit: April 19, 2008, 11:06:23 am by Megiddo »
Re: RFC: Common Prop Protection Interface (CPPI)
« Reply #1 on: April 16, 2008, 02:52:57 pm »
Posted here to keep it somewhere under my control. (Was on FP)
