SVN internals updated
Topic: SVN internals updated (Read 6180 times)
Megiddo
Ulysses Team Member
Project Lead
April 16, 2008, 10:46:16 pm »
Hey all,
I updated the main SVN repository so that all the individual projects are running on their own repository linked into the main one. You shouldn't really notice any difference unless you actually read the svn update output, but let me know if you run into any issues due to this change.
Thanks!
p1cwh0r3
Re: SVN internals updated
April 17, 2008, 09:14:33 am »
I'm getting "Error: Target path does not exist"
Ultrabograt
Guest
Reply #2 on:
April 17, 2008, 09:26:33 am »
I am also getting "Error: Target path does not exist". It appears there are only installers and a folder called ND in the repository now. The main repository is moved or gone.
Ultrabograt
Guest
Reply #3 on:
April 17, 2008, 09:37:38 am »
Well there is no need to worry you simply need to start downloading from a new path:
svn://ulyssesmod.net/ulx/trunk
(for ulx)
svn://ulyssesmod.net/ulib/trunk
(for ulib)
Sorry for my earlier moan, it was my fault entirely.
Well thanks for making this great mod.
spbogie
Ulysses Team Member
Sr. Member
Reply #4 on:
April 17, 2008, 10:17:56 am »
Hmm, well, there haven't been any changes to the code on the svn since this change, so I would recommend leaving it as is for now, and I'll make sure Megiddo looks into getting the addresses pointing back where they were.
Megiddo
Ulysses Team Member
Project Lead
Reply #5 on:
April 17, 2008, 11:30:28 am »
It appears you can't checkout from an external, so I updated the necessary information in our stickies.
