Author Topic: Error: Target path does not exist, when trying to update  (Read 19985 times)
Benie08
« on: April 17, 2008, 10:42:05 pm »
Hi all. Trying to update my SVN versions of ULX and Ulib, and I'm unable. I can't seem to change the target path either.
I'm using TortoiseSVN.
Re: Error: Target path does not exist, when trying to update
« Reply #1 on: April 17, 2008, 10:49:42 pm »
Updating your SVN does not work anymore. You'll need to create a new folder are start a new dump. Meg changed something about the way it's structured.
Offline Avien
« Reply #2 on: April 18, 2008, 03:24:05 pm »
Why the change?  Something happen to the old way it was done?
« Reply #3 on: April 18, 2008, 05:23:56 pm »
This way works better for us
Offline Cornflake
« Reply #4 on: April 18, 2008, 09:28:41 pm »
Also it seems that a different path is used.
Instead of: "svn://ulyssesmod.net/Ulysses/ulib/trunk" it is now: "svn://ulyssesmod.net/ulib/trunk". That's why I couldn't check out. Although it's very strange, I just checked out ULX fine, but Tortoise SVN is hanging when it goes to checkout Ulib. Very strange. I hit cancel and look, it shows only the .svn folder filled out  :(
