Offline Botman
Re: UPS - Ulysses Prop Share
« Reply #405 on: January 02, 2011, 11:09:19 am »
Sorry for being a little unclear there. Yes, I was using the latest SVN versions of ULiB and ULX (I've been away and just got back now). Anyway, I haven't really made any serious effort to solve the problem on my own, I just compensated for it by installing SPP and then I had to go for a few days.
« Reply #406 on: January 02, 2011, 01:30:42 pm »
Botman, if you haven't already, see Megiddo's previous post to yours. He mentions a possible Gmod bug, and wishes to test/determine/maybe hack around it (we're used to doing that).
Offline krooks
  • I don't like video games.
    • Diamond Krooks
« Reply #407 on: January 04, 2011, 09:57:33 am »
I'm having a couple problems with UPS,
First off, I am using SVN everything, on a Linux server.
Megiddo, on page 26 I noticed you adressed this issue already, which is changes not saving between map changes/ restarts, but you said you had code to manually save those changes, was this code ever implemented? It would be very handy.
The second issue is Admins are not able to clean up props fromt he admin pannel, only I am (super admin). Was it written to be this way or am I perhaps doing something wrong?
My admin group is not named "admin", using UTeam, but on that note, neither is my super admin group named "super admin" so I don't think that would do it.
Any ideas? Thanks.
« Last Edit: January 04, 2011, 10:01:57 am by krooks »
My TTT server. Join the fun!
« Reply #408 on: January 04, 2011, 10:59:57 am »
We haven't implemented those changes yet, no, but the framework to do it is all in place. I'm working to wrap up some issues in ULX and ULib in the next few days, and then I should be able to work on UPS cvar saving after that (but no promises).
Any ideas? Thanks.
Use the following command in console:
ulx groupallow your_group_name "ups miscDeletionAccess"
Where "your_group_name" is the name of the group (not team! group name as defined in groups.txt) you want to give access.
Thanks for such a lucid, forthright help request. It seems I can hardly ever address someone's request without asking them more questions about what they want. ;)
Offline krooks
    • Diamond Krooks
« Reply #409 on: January 04, 2011, 03:10:32 pm »
Thank you much, I will give that a try and will look forward to future updates!
I'm no Lua coder, but I do websites and know computers in general. I get tons of help requests and feel your pain  ;)
*EDIT*
just tried the command and it worked flawlessly, thanks!
« Last Edit: January 04, 2011, 04:46:31 pm by krooks »
« Reply #410 on: January 04, 2011, 04:51:45 pm »
No problem :)
« Reply #411 on: January 08, 2011, 02:43:03 pm »
Instant cvar saving got added to UPS SVN last night. The new UPS will be officially released along with the new ULib, ULX, and XGUI. Hopefully sometime within the month...
« Reply #412 on: January 08, 2011, 08:28:03 pm »
Sounds good, I had to set them with my cfg file.
Offline krooks
    • Diamond Krooks
« Reply #413 on: January 17, 2011, 11:50:26 pm »
Awesome cant wait!
I would like to just say that I have been having issues with UPS not allowing any admin overrides. I like to allow buttons/ vehicles across the whole server so that people don't need to mess with adding friends etc for simple things like "use my trap". But it keeps working then not working, I'm assuming its going in and out with every time I update my SVN, but I can't be positive about that.
This is just a heads up for your future release.
« Reply #414 on: January 24, 2011, 08:33:29 am »
I have a picture of that bug I was talking to you about.  He cannot pick up his props.  We cannot clean his props.
Yes, it is sniper10's props.
« Reply #415 on: July 05, 2011, 06:02:35 pm »
Much later than it should be, but here's 0.96!
Quote from: changelog
v0.96 - *(07/05/11)*
   * [ADD] Global disables.
   * [ADD] Our own cvar saving to get away from Garry's terrible version. Now saves changes instantly.
   * [FIX] Restored saving functionality for player disables (not sure when this got broken, sorry. Thanks AtomicSpark).
   * [CHANGE] Moved replicated cvar stuff to ULib and improved it a bit.
   * [CHANGE] Won't show HUD while in vehicle anymore.
   * [CHANGE] Saved data is under data/ups now.
   * [CHANGE] UPS won't load in single player.
« Reply #416 on: October 23, 2011, 05:14:47 pm »
« Reply #418 on: October 30, 2011, 12:57:26 pm »
Do you still have this problem after Garry cleared up the API issues?
I will need to check on this right now. The thing is its only happening with a certain person.
« Reply #419 on: October 30, 2011, 01:41:07 pm »
It was the same with me.  It only happened to a few people when I was hosting my server.
