Author Topic: Problem adding admins  (Read 5678 times)
Peter
« on: May 01, 2008, 09:03:30 am »
I have problems adding admins to my users.txt. I have read the Admin article on wiki like 3 times, I have checked the Steam ID not 2 times but 4 times. And still can't get it worked. Something is very very weird, I have added my friends to the adminlist and they are successfully are admin. I have tried different things but I just can't get it worked for me. The server say You not have access to that command when I type ; ulx debuginfo. I have restarted my server after changing stuff.
Nothing seems to work, What now ?
I'm so desperate ...
Re: Problem adding admins
« Reply #1 on: May 01, 2008, 09:55:28 am »
Use ulx debuginfo in the server console while connected.
[EDIT] Jamminr - Modified word for clarity
« Last Edit: May 01, 2008, 10:14:42 am by JamminR »
peter
« Reply #2 on: May 01, 2008, 01:52:52 pm »
I have already tried, but it says the whole time; "You don't have access to this command, [GU]peter99" and yes im logged in at rcon
peter
« Reply #3 on: May 01, 2008, 02:05:22 pm »
[UPDATE] The problem seems to be disappeared, I don't know how because I was at a friend's house. but I'm admin!
Offline Bounty_Bam
« Reply #4 on: May 23, 2008, 11:09:46 am »
My problem hasnt dissappeared, EVERYTHING i say is "you dont have access to this command Bam"???
« Reply #5 on: May 23, 2008, 03:48:01 pm »
SERVER console has no name but 'Console'
If it told you that error, then you weren't running it from server console.
rcon_password <password>
rcon ulx debuginfo
Server console will spit out where the debug file is. Game console may not.
