Author Topic: Warning: Unhandled Usermessage (SVN)  (Read 17712 times)
Offline anticept
« on: May 01, 2008, 03:53:22 pm »
I periodically get this console spam on my client on connecting to my server, and I have no idea whats causing it. Usually reconnecting clears it right up.
I read somewhere scriptenforce can cause this, but I am not running scriptenforce... I am running some other mods however. I can list them if needed.
Warning: Unhandled usermessage 'ulx_resetinfo'
Warning: Unhandled usermessage 'ulx_autocomplete'
Warning: Unhandled usermessage 'ULib_autocomplete'
Warning: Unhandled usermessage 'ULibUserUCL'
Warning: Unhandled usermessage 'ULibAllowUCL'
Warning: Unhandled usermessage 'ULibGroupUCL'
Warning: Unhandled usermessage 'ULibFinishedUCL'
Warning: Unhandled usermessage 'ulx_map'
Warning: Unhandled usermessage 'ULXMotdStart'
Warning: Unhandled usermessage 'ULXMotdText'
Warning: Unhandled usermessage 'ULXMotdEnd'
Warning: Unhandled usermessage 'SendMotdMenu'
Re: Warning: Unhandled Usermessage (SVN)
« Reply #1 on: May 01, 2008, 04:27:50 pm »
Generally from a slower client. It's on the to look at list though.
« Reply #2 on: May 01, 2008, 05:04:28 pm »
this happens with anything that sends usermessages, particularly a LOT of them. It has to do with the way your client tries to read them too fast or something. Generally reconnecting to the server resolves the problem.
Offline anticept
« Reply #3 on: May 18, 2008, 01:31:22 pm »
Is it possible to wait for the client to recieve so many usermessages, and then let ULX wait until it sends acknowlegement before sending more?
« Reply #4 on: May 18, 2008, 03:17:09 pm »
Yes but that introduces many problems you don't want to get into.
Offline anticept
« Reply #5 on: May 19, 2008, 05:15:01 pm »
What is a usermessage used for then?
And is it possible to concatenate multiple usermessages into one, and then use string.find to sort of decrypt it?
« Reply #6 on: May 19, 2008, 05:47:44 pm »
See "What are they" at the Gmod Wiki - Usermessages
Yes, if it were a single string. Our motd (and my UMotd) uses a similiar idea to string several together, which, leads to my "No".
 A user message has a limited byte size, they're also many different kinds.
Offline Lorua
« Reply #7 on: June 05, 2008, 05:27:09 pm »
Would be nice if there is a fix for this. I also get this errors and there is no chance to use any console commands after the map changes.
Offline AviZ
« Reply #8 on: June 07, 2008, 03:08:17 pm »
reconnect and problem solved.
Offline anticept
« Reply #9 on: June 10, 2008, 07:16:43 pm »
Side note:
Mind changing server.ini in the config folder, to server.ini.example? I forget to delete it sometimes before uploading to my ftp. :)
« Reply #10 on: June 10, 2008, 07:19:10 pm »
See pro tips in our FAQ section.
Offline Lorua
« Reply #11 on: June 15, 2008, 04:59:27 am »
Ehm, it's really annoying reconnect the server after each mapchange (ever played ZS?).
Before the new source engine was added to Gmod, ZS and ULX worked great together. Now, just some chatcommands are working and all of the con commands are broken.
« Last Edit: June 15, 2008, 05:03:36 am by Lorua »
Offline WildWill
  • Global Moderator
    • Beast_Building_Server
« Reply #12 on: July 02, 2008, 01:04:00 pm »
Pretty sure this should be fixed now. Try updating you ULX via SVN.
Edit: Whoops, yes I should say ULX/ULIB
« Last Edit: July 02, 2008, 09:30:18 pm by WildWill »
Offline spbogie
« Reply #13 on: July 02, 2008, 03:06:21 pm »
The main fix for it is actually in ULib, but yes, update both.
« Reply #14 on: July 27, 2008, 10:47:03 pm »
I may have found something usefull to you, perhaps you already know about it, but if not here it is :D.
sv_usermessage_maxsize                   : 1024     : , "sv"           : The max number of bytes to output per tick
I found this while looking through the garrysmod cvarlist. (Got bored with extra time)
