Author Topic: MOTD is broken.  (Read 10439 times)
Pieanator
MOTD is broken.
« on: May 12, 2008, 04:44:57 pm »
On my server (dedicated) the MOTD is broken, as in it doesn't show up at all. When you join, do !motd, or from !menu, it just doesn't show up.
Halp? ???
Re: MOTD is broken.
« Reply #1 on: May 12, 2008, 05:11:10 pm »
assuming this is even a problem and not simply user error. This could be caused by many things. You'll need to provide some more info or no one will be able to help you.
Also. it's HELP not HALP.
Offline spbogie
Re: MOTD is broken.
« Reply #2 on: May 12, 2008, 05:32:50 pm »
Release or SVN version? (information which should have been provided in the OP).
If it's Release, then it won't work because garry removed the motdfile cvar.
Pieanator
Re: MOTD is broken.
« Reply #3 on: May 12, 2008, 05:53:20 pm »
I don't know, I just downloaded the one from the home page or whatever.
Pieanator
Re: MOTD is broken.
« Reply #5 on: May 13, 2008, 01:16:41 pm »
So am I just supposed to download the mantis thing?
I don't understand.
Re: MOTD is broken.
« Reply #6 on: May 13, 2008, 03:01:39 pm »
Mantis is our bug tracker. So, no, you don't download Mantis.
SVN is where developers keep/code/corroborate on the latest pre-release code.
You have access to SVN, but, it sounds as though you might want to wait for the next release.
I don't know when that will be.
(And, even though it's in _our_ bug tracker, we wish to make clear, Garry broke our MOTD not working, we just found a way around it)
Offline AviZ
Re: MOTD is broken.
« Reply #7 on: May 21, 2008, 04:39:54 am »
motd is still broken even in the svn, infact the adminmenu no longer works either...
any news?
Megiddo_at_work
Re: MOTD is broken.
« Reply #8 on: May 21, 2008, 05:52:22 am »
Works for us (at least the motd, haven't tested admin menu in a while).
Offline AviZ
Re: MOTD is broken.
« Reply #9 on: May 21, 2008, 11:11:12 am »
the admin menu comes up blank, as in nothing in it, just a small box with a x in it
Don PC Costella
Re: MOTD is broken.
« Reply #10 on: June 10, 2008, 01:08:48 pm »
My MOTD show up, but it shows a map circle on TF2 or something, it doesnt show the text from motd.txt
Don PC Costella
Re: MOTD is broken.
« Reply #11 on: June 10, 2008, 01:29:53 pm »
Re: MOTD is broken.
« Reply #12 on: June 10, 2008, 02:18:05 pm »
Hmm, that's interesting, a non-standard tf2 motd. Just stick the motd.txt in your garrysmod root.
Don PC Costella
Re: MOTD is broken.
« Reply #13 on: June 11, 2008, 02:35:30 am »
Garrysmod Root? can you explain what you mean?
Don PC Costella
Re: MOTD is broken.
« Reply #14 on: June 11, 2008, 02:42:58 am »
Nevermind, i found out, thank you very much ;D
