Author Topic: ULX Command Limits  (Read 8504 times)
Offline Bounty_Bam
ULX Command Limits
« on: June 02, 2008, 02:47:35 pm »
I was just wondering, is there anyway I can edit the group.txt so that admins/operaters CANT use admin commands on Superadmins?
This would be SO helpful :)
Re: ULX Command Limits
« Reply #1 on: June 02, 2008, 02:54:28 pm »
Isn't this the default behavior? Only superadmins can overcome immunity.
Offline Bounty_Bam
« Reply #2 on: June 02, 2008, 03:07:54 pm »
I thought so, but admins can !slay me, !ragdoll me ect  :-\
Offline spbogie
« Reply #3 on: June 02, 2008, 06:23:27 pm »
did you give yourself immunity?
« Reply #4 on: June 02, 2008, 07:10:18 pm »
Technically, immunity is not set by default.
A superadmin adding themself would have to specify immunity, or it doesn't get set.
I also just realized, if they didn't use 'adduser', and followed our strongly recommended directions for adding to Garrysmod settings/users.txt ... immunity doesn't get set for superadmins.
Perhaps in the future we should consider making superadmins immune by default, all others not, unless specified by adduser.
Offline Bounty_Bam
« Reply #5 on: June 03, 2008, 12:15:47 am »
So i type something along the lines of :
ulx adduser "Bam" superadmin [1]
« Reply #6 on: June 03, 2008, 12:16:52 am »
you don't need the brackets.
adduser yourname superadmin 1
« Reply #7 on: June 03, 2008, 12:45:09 am »
Ok, to clear things up.
if the name doesn't contain an spaces or symbols, you can just type their name EX: adduser bob group
if there is a space or symbols you have to use quotes EX: adduser "bob thorton" group
same thing applies for all arguments, so for immunity is only a single digit number so no spaces
so it would be:
adduser bob superadmin 1
adduser "bob thorton" superadmin 1
Offline Bounty_Bam
« Reply #8 on: June 03, 2008, 03:35:14 am »
Thanks for your help guys....now I just have one major request.
I entered game to try out the new command line, I dnt have access to this command :S
Now I go to my groups.txt...and this is what it says:
"superadmin"
thats it.. ALL my information & configuration is gone somehow :(
I was just wondering if someone could send me a default groups.txt via email? Or is there a way to refresh my current file?
My email is: bam_boostick@hotmail.com
i WILL get this sorted :) cheers
Offline Bounty_Bam
« Reply #9 on: June 03, 2008, 07:53:14 am »
sorted....i re installed :)
« Reply #10 on: June 03, 2008, 11:54:44 am »
If you ever want to get a clean groups.txt file, delete your current one from garrysmod/data/ULib and then simply restart your server and ULib will build a new one.
« Reply #11 on: June 03, 2008, 05:06:51 pm »
Many people don't follow the instructions in Ulib addons group.txt (Though, many have trouble understanding it)
Never edit /addons/ULib/data/ulib/groups.txt
:) :D
If you're going to make custom groups file,
ALWAYS create/edit a NEW <gmod root>/data/ULib/groups.txt (<--<<---- notice, there is no addons folder there)
Then when it totally breaks, you can follow Mr.Presidents instructions
