Author Topic: ULX 3.31 - Sem Culpa  (Read 15207 times)
« on: June 08, 2008, 10:58:25 am »
This release includes a few fixes for bugs from ULX 3.30, and a few fixes for bugs garry introduced. This release has been codenamed Sem Culpa. There's also a ULib update. You won't need the ULib update to run ULX 3.31, but it's recommended you get it anyways.
Here's the changelogs...
Quote from: ULX changelog
v3.31 - *(06/08/08)*
   * [ADD} ulx adduserid - Add a user by steam id (ie STEAM_0:1:1234...) (Does not actually verify user validity) (Thanks Mr.President)
   * [FIX] Garry's 1/29/08 update breaking MOTD.
   * [FIX] Links not working on MOTD.
   * [FIX] Bug where you'd be stuck if someone disconnected while you were spectating them.
   * [FIX] TF2 motd showing by default.
   * [FIX] The usual assortment of small fixes not worth mentioning.
   * [CHANGE] Unignite help command changed to be more standardized with other help.
   * [CHANGE] Help indicates that multiple users can now also be command targeted using an asterisk "*". (ULib change added this)
   * [CHANGE] Miscellaneous spelling corrections.
   * [CHANGE] ulx chattime so that if your chat doesn't go through it is not counted towards your time.
   * [CHANGE] Can no longer set hp or armor to less than 0.
   * [REMOVE] ulx mingekick, useless now.
Quote from: ULib changelog
v2.21 - *(06/08/08)*
   * [ADD] Support for client/server-side only modules.
   * [FIX] Bug in ULib.tsay that would incorrectly print to console if the target player was disconnecting.
   * [FIX] Makes sure that prop protectors don't take ownership of props using physgun reload while a prop is unmovable.
   * [CHANGE] ULib.getUsers now returns multiple users on an asterisk "*" when enable_keywords is true. "<ALL>" can still be used. (Thanks Kyzer)
As always, download these files on our homepage at ulyssesmod.net
Thanks to those who were patient enough to give SVN a whirl and provide feedback!
Offline Chironex
  • Formerly known as Kyzer
Re: ULX 3.31 - Sem Culpa
« Reply #1 on: June 09, 2008, 10:22:57 am »
Nice ;D
I miss the Mingebags :'(
Offline benbrooks
« Reply #2 on: June 11, 2008, 09:55:06 am »
I've just tried updaing ULX and Ulib on my server and after two restarts it's still not working, I've tried my old 3.30 configs and the defaults that came.
I think ULX is the problem because I still get my 'Owner' group given to me, I can noclip through props with uClip on etc.
Downgrading ULX for now, I'll probably have a longer go at upgrading later on tonight when the server is quiet.
My bad, Forgot to update/upload the cache files to my downloadurl server.  :-[
« Last Edit: June 11, 2008, 01:19:35 pm by benbrooks »
