Author Topic: Css Props/tools  (Read 6608 times)
cs_Chip
Css Props/tools
« on: June 15, 2008, 05:49:00 am »
On My Server I cant add css Props like Office and .....
Why ??
// Bad English !
Re: Css Props/tools
« Reply #1 on: June 15, 2008, 06:29:50 am »
You probably don't have CSS content installed on the server.
Please See Garry's mod wiki "Dedicated Server Setup" http://wiki.garrysmod.com/wiki/?title=Dedicated_Server_Setup
sushi power
Re: Css Props/tools
« Reply #2 on: June 15, 2008, 06:46:43 am »
i dont have css props on me server and i dont understand this
 Counter-Strike: Source
To install the Counter-Strike Source content, all you need to do is re-run the hldsupdatetool:
hldsupdatetool -command update -game "Counter-Strike Source" -dir C:\srcds
  plzz help  ???
Re: Css Props/tools
« Reply #3 on: June 15, 2008, 07:48:24 am »
If you're paying for a dedicated (hosted) server, then ask them for help.
If you're using dedicated server, you install CSS the same way you installed Gmod, but with different commands as you just typed.
If you're using Listen server (hosting from your game), you only have CSS if you already have it installed.
Please use Off-Topic for questions like this. You keep posting in "ULib/ULX support only" thread and should not.
Also, since you have a hard time understanding english, you maybe should find someone who can help you in your own language.
Those instructions are simple if you know english.
« Last Edit: June 15, 2008, 07:50:02 am by JamminR »
