Author Topic: add Other to admin  (Read 14027 times)
cs_chip
add Other to admin
« on: June 16, 2008, 01:51:12 pm »
 i cant add other to admin how i do to add ??
like cs_chip .. STEAM_0:1:17866083  ???
Thx For Help
//cs_ChipGarrysmod
cs_Chip
Re: add Other to admin
« Reply #1 on: June 16, 2008, 01:59:51 pm »
Thx For Help
//cs_ChipGarrysmod
BTW i dont understand that help on www.garrysmod ...... to add css props like office ... plzz help ?
Offline cs_chip
  • 85.229.17.167:27015
« Reply #2 on: June 16, 2008, 02:14:44 pm »
« Last Edit: June 16, 2008, 02:21:38 pm by cs_chip »
Garrys mod server 85.229.17.167:27015
« Reply #3 on: June 16, 2008, 03:44:39 pm »
/index.php/board,30.0.html <----------- Read first.
As for this I will help you.
I'm guessing since you got gmod installed, you know how to install other games as well, so here it is.
hldsupdatetool -command update -game "Counter-Strike Source" -dir C:\srcds
This will install css to the c:\srcds directory, only problem with that is, gmod is in the c:\srcds\orangebox\
directory. Simple fix, after completing the download of css simply drag the css folder into the orangebox folder.
that's for the server, if you were talking about adding css props to your garrysmod and not the server, then the only way is the purchase
css.
« Reply #4 on: June 16, 2008, 03:49:24 pm »
Stop spamming our forums or JamminR will maul you.
« Reply #5 on: June 16, 2008, 05:01:48 pm »
:D that is so going in my signature.
Offline cs_chip
« Reply #6 on: June 17, 2008, 03:42:00 am »
css.
so where i put this code hldsupdatetool -command update -game "Counter-Strike Source" -dir C:\srcds ???? and i msot reinstall css ?
« Reply #7 on: June 17, 2008, 04:03:13 am »
Is this server on your computer, or did you pay for it?
Offline cs_chip
« Reply #8 on: June 17, 2008, 04:53:11 am »
on my computer ...
cs-Chip
Offline cs_chip
« Reply #9 on: June 17, 2008, 06:14:58 am »
i can only have gm_construct or gm_flatgrass on my server .. when i have like gm_megaconstruckt_v4 its come for all missing map ... =/ ???
//cs_chip
« Reply #10 on: June 17, 2008, 07:40:29 am »
We cannot and will not support illegal servers.
« Reply #11 on: June 17, 2008, 03:33:46 pm »
i downlaod it from thepiratebay ....
1) Majority of the questions you ask have nothing to do with ULX or ULib.
You need to find your own tutorial, in your own language, for how to run a server before ever attempting to use ULX.
2) What Megiddo said. We will not support downloaded Gmod.
If you want to run a server and play on it too, buy the game.
Offline cs_chip
« Reply #12 on: June 18, 2008, 02:43:57 am »
i haved buy the game .. but i downloaded server propgram ?
« Reply #13 on: June 18, 2008, 03:01:58 am »
Never download server programs, especially from a pirating site. This only lowers performance and doesn't guaranty quality
Follow the instructions here for installing a proper server. http://srcds.com
Once completed I would be more then willing to help.
