Author Topic: GMOD HELP  (Read 10146 times)
Offline Jarviar
GMOD HELP
« on: June 18, 2008, 03:12:03 pm »
 Here is an error i basically become a ghost from it any fix?
ERROR: GAMEMODE:'PlayerSpawn' Failed: sandbox/gamemode/init.lua:40: stack overflow
It occours when i play something other thatn sandbox offline/lan.
Re: GMOD HELP
« Reply #1 on: June 18, 2008, 03:37:29 pm »
It means you have a bad script installed.
Offline Jarviar
Re: GMOD HELP
« Reply #2 on: June 18, 2008, 05:05:24 pm »
Could you help me locate it because the sandbox game mode is but i get the error with the others and i made sure the game mode files weren't messed up.
I'm going to clean out old addons but probably not going to fix.
EDIT: didnt work anyone know what to remove/fix?
« Last Edit: June 18, 2008, 10:46:50 pm by Jarviar »
Offline Jarviar
Re: GMOD HELP
« Reply #3 on: June 19, 2008, 09:02:12 pm »
Reply?
Re: GMOD HELP
« Reply #4 on: June 19, 2008, 10:26:12 pm »
1. Server installed on your computer or rented?
2. If installed on you computer, where did you get it from?
3. Is it a clean install, or have you changed/added anything?
Offline Jarviar
Re: GMOD HELP
« Reply #5 on: June 19, 2008, 11:09:48 pm »
I said before lan/singleplayer HELP ME FIX!!!
Re: GMOD HELP
« Reply #6 on: June 20, 2008, 03:37:37 am »
HELP ME FIX!!!
No he didn't.
* JamminR looks again.
Yes he did.
Wipe Gmod.
Reinstall Gmod, no addons. See if it works. Then add each addon back one at a time like everyone else would have to do to find out what broke it.
It's not our problem, It's nothing to do with ULX or ULib.
Find your own fix. I'm not even going to look at this thread anymore if it pops up in my unread list.
[Edit - JamminR] - Word added/clarified
« Last Edit: June 21, 2008, 05:13:32 am by JamminR »
Offline Jarviar
Re: GMOD HELP
« Reply #7 on: June 20, 2008, 08:30:21 pm »
Just wiped and put my required addons such as wiremod / spacebuild and i wiped out most of my little addons then moved the stuff over but no luck.
Re: GMOD HELP
« Reply #8 on: June 20, 2008, 08:58:17 pm »
Skipped a step:
Wipe Gmod.
Reinstall Gmod, no addons. See if it works. Then add each addon back at a time like everyone else would have to do to find out what broke it.
Unless I misread you post
Offline Jarviar
Re: GMOD HELP
« Reply #9 on: June 23, 2008, 11:20:23 pm »
Alright i wiped and went ahead and kept all addons removed weapons folder and removed some files and it works i cleared about 48% of unneeded and it works.
SOO... It's good wouldhave posted earlier about my succes but my internet has been going out.
