Author Topic: Map Change breaks console commands  (Read 8932 times)
Offline brocko
« on: June 27, 2008, 09:26:03 pm »
This could just be on my server.. but any help is great.  After a map change (via ULX), too many server disconnections (white screen after crash) or too much alt-tabbing, ULX console commands no longer work. Attempting to use them gives the following error, as though they do not exist;
Unknown Command: 'ulx'
Re: Map Change breaks console commands
« Reply #1 on: June 28, 2008, 12:42:16 am »
You can either reconnect to the server manually or you can type retry in your console. Then you should be good.
Offline brocko
« Reply #2 on: June 28, 2008, 12:51:12 am »
Is there any way to prevent this from happening, or to fix it?
Thanks
« Reply #3 on: June 28, 2008, 01:15:54 am »
Not that I've found, but I'm pretty sure this would be an issue with Garry and not ulysses.
Offline DC
« Reply #4 on: July 01, 2008, 09:38:53 pm »
I have this same problem with the server we have. Hopefully someone can get a solution.
« Reply #5 on: July 02, 2008, 02:48:07 am »
We made a workaround yesterday.
« Reply #6 on: July 02, 2008, 03:15:40 am »
We placed it in our SVN though, not yet a release.
DC, others, If you aren't wishing to use SVN and test for us, perhaps ask your other hosting friends to.
Offline DC
« Reply #7 on: July 02, 2008, 07:26:13 pm »
Any clue when this problem will be fixed in an update then?
« Reply #8 on: July 03, 2008, 03:31:04 pm »
After much testing
« Reply #9 on: July 03, 2008, 03:50:39 pm »
I've tested the svn with several map changes and it appears to be working just fine.
« Reply #10 on: July 03, 2008, 03:57:14 pm »
Woot, woot! Gravy train time.
