Author Topic: Setting up Reserve Slots  (Read 4325 times)
Offline Waphlez
« on: June 29, 2008, 07:25:19 pm »
I've searched for documentation to set up reserve slots but came up empty. I also want it so that it doesn't completely block out a slot (ie preventing someone from taking the slot) but only kicks somebody off the server if somebody with a reserved slot connects to the server, if that is possible. So if anybody will be so kind as to give me help with setting this up please do, wither it is ULX or something else.
Re: Setting up Reserve Slots
« Reply #1 on: June 29, 2008, 07:30:52 pm »
The documentation is in the config file (server.ini). Look at addons/ulx/cfg/server.ini. Also, look at our "pro tips" section under FAQs, gives hints on how to keep your config files from being overridden in future versions of ULX.
Offline Waphlez
« Reply #2 on: June 29, 2008, 08:19:16 pm »
Okay, thank you.
