Author Topic: Loading Problem  (Read 12595 times)
WOW
Loading Problem
« on: August 26, 2006, 01:57:40 pm »
Ok When I start the Script I get this Error:
//            ULX            //
//  util.lua                 //
//  fun.lua                  //
//  menus.lua                //
Lua Error: Line 55: attempt to index field 'ucl' (a nil value)
LUA: Errors when running script 'ulx/end.lua'
How can I Fix this?
WOW
Re: Loading Problem
« Reply #1 on: August 26, 2006, 02:29:52 pm »
Ok Fixed that now it says something like: [UCL] Why are you trying to login anyway you have no accsess or" Or something like that.
How do I fix this
WOW
Re: Loading Problem
« Reply #2 on: August 26, 2006, 02:41:52 pm »
Ok here is what it says:
[UCL] Why are you trying to enter a password when you have no access at all?
Re: Loading Problem
« Reply #3 on: August 27, 2006, 04:52:45 pm »
Using ULX v2?
When you say 'loading'...do you mean you have ulx_init.lua in your gmod9/lua/init folder?
And if yes to both above, what do you have in your lua/ulib/users.ini ?
WOW
Re: Loading Problem
« Reply #4 on: September 17, 2006, 08:12:51 am »
My Steam ID and Username.
Re: Loading Problem
« Reply #5 on: September 17, 2006, 08:40:17 am »
Try reinstalling the scripts.
Re: Loading Problem
« Reply #6 on: September 17, 2006, 06:07:12 pm »
Both?  ???
Please specifically paste what you have in your users.ini
WoW
Re: Loading Problem
« Reply #7 on: September 20, 2006, 07:24:05 pm »
Ok I installed the newest version. But now I don't get any opoins on the menu. I can login but I get no options
Re: Loading Problem
« Reply #8 on: September 20, 2006, 07:34:52 pm »
Add yourself to users.ini
WoW
Re: Loading Problem
« Reply #9 on: October 12, 2006, 04:24:31 pm »
I did. I am going to check the user file
Re: Loading Problem
« Reply #10 on: October 12, 2006, 08:03:31 pm »
Can you post the users.ini?
WOW
Re: Loading Problem
« Reply #11 on: October 20, 2006, 02:33:17 pm »
Ok I login but the menu is blank? so now what?
Re: Loading Problem
« Reply #12 on: October 20, 2006, 03:46:33 pm »
WOW
Re: Loading Problem
« Reply #13 on: October 23, 2006, 05:43:00 pm »
Still does not work. Ok I don't host servers on the internet only on LAN can you make it so anyone can accsess the Menu?
Offline spbogie
Re: Loading Problem
« Reply #14 on: October 25, 2006, 04:33:33 pm »
Please post your users.ini file. If you are running on LAN then a Steam ID will not work. If you just want to give all Lan users access then using STEAM_ID_LAN for the steam id should work.
