Poll
Good idea ?
<censor> Yea Will Be Usefull
9 (60%)
Yea
6 (40%)
Maybe
0 (0%)
Not sure
0 (0%)
No
0 (0%)
Total Members Voted: 0
Author Topic: ULXToolRestricter  (Read 19520 times)
Offline RecoX
  • Hey, Yea im not the best at lua but im lerning
ULXToolRestricter
« on: July 05, 2008, 11:53:19 am »
WARNING!: If you have ASpam installed You must update it to latest !
New Name: ULX Anti-Stool
Version: 1.1.2
Author: Reco / With Help from Jay209015
Purpose:
--------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------This Module will stop normal users from using a certen tool EG; Anti-NoClip Stool will be restirected to Allowed list and admins
How To Install:
Simply drop the lua file in your lua/autorun-
How to add users:
Open up garrysmod/data/antistool_palyers.txt and add the steam ids that you want.
Download--------------------
http://one.xthost.info/AnstiStool/Anti-Stool%20Version%201.1.zip]http://one.xthost.info/AnstiStool/Anti-Stool%20Version%201.1.zip]http://one.xthost.info/AnstiStool/Anti-Stool%20Version%201.1.zip
« Last Edit: July 12, 2008, 04:18:19 am by RecoX »
Reco Will Allways Help!
Offline RecoX
Re: ULXToolRestricter
« Reply #1 on: July 05, 2008, 11:56:43 am »
This is just the verry basic code im  hoping with a few more tuts to make it so you can add restricted tools in a cfg or txt file
Offline benbrooks
« Reply #2 on: July 06, 2008, 06:24:20 am »
Looks simple but effective, nice work :)
Offline RecoX
« Reply #3 on: July 06, 2008, 07:55:14 am »
Thanks Also im ahving proplems in my servers all pepole can pick echover up
« Reply #4 on: July 06, 2008, 09:24:31 am »
Welcome to the forums RecoX! Sit back, relax, and let the crazy do its work. :)
Offline Chironex
  • Formerly known as Kyzer
« Reply #5 on: July 06, 2008, 10:12:30 am »
Do something more newb-friendly, something like that:
-- Here they write all tools they want to restrict:
local Restricted_Tools =
    "#Anti-NoClip",
    "Gcombat",
    "Cannon",
    "linktool"
--and then in your function, you just check if the toolmode is one of that list:
if Restricted_Tools[toolmode] then
Offline RecoX
« Reply #6 on: July 06, 2008, 10:52:55 am »
Thanks Medigeo (hopfly spelt right didn't look) And ill try to make something more newb friendly
Offline RecoX
« Reply #7 on: July 06, 2008, 11:07:28 am »
Ive Added the Nweb Freindly stool adder and im also working on allowed players via steam ids is it ply:SteamID() ?
« Reply #8 on: July 06, 2008, 03:13:22 pm »
The hook needs to be after the function
hook.Add( "CanTool", "GetTool", gettool)
This will only work for the first table entry:
if ply:SteamID() == Allowed_players then return true
Try something like:
table.HasValue(Allowed_players, ply:SteamID()) then return true
And where's the function "UseTool" that you are calling with this hook?
hook.Add( "CanTool", "UseTool", UseTool );
Offline RecoX
« Reply #9 on: July 07, 2008, 07:20:50 am »
Well getting that it wont checkif your amdin when you slect a tool maybe ill try if you use a tool thats restricted without being an admin
Offline RecoX
« Reply #10 on: July 07, 2008, 11:26:28 am »
Ive added Ant-Stool:Anti-Sent Stops a non admin from spawning a sent and has an exclusion list like the others
Offline Chief_runningwater
  • Fpsbanana User
    • Chiefrunningwater.com
« Reply #11 on: July 07, 2008, 01:32:43 pm »
How would I add this to my server, I'm a little confused on how to set this up....
Offline RecoX
« Reply #12 on: July 07, 2008, 11:50:20 pm »
Well currently you can't as its not checking proply :)
But the way you set it is real simple
Add your steam ids you want it not to affect
and put in lua/autorun
  • Fpsbanana User
« Reply #13 on: July 08, 2008, 11:00:40 am »
Thanks that helped a lot now all I need to do is wait till you release it  ;D
Offline spbogie
« Reply #14 on: July 08, 2008, 02:14:05 pm »
-- Add your restrected tools here
    "#Anti-NoClip",
   "adv_duplicator",
    "Gcombat",
    "Anti-NoClip",
    "linktool",
   "stacker",
--Add your steam id's that this should not affect
local Allowed_players =
    "STEAM:1:0:5447", -- Don't forget to remove this  Lay out exactly like that so "STEAM:1:0:88888",    "
 function gettool(ply, tr, toolmode)
   if pl:IsAdmin() then return true
   if pl:SuperAdmin() then return true
   if return false then
   ply:PrintMessage(HUD_PRINTTALK, "ULXAnti-Stool: Sorry But your not an Admin, Or In the Excluded Player List")
