Author Topic: GMOD server help  (Read 9386 times)
Offline Jarviar
GMOD server help
« on: July 08, 2008, 12:00:22 am »
I want to get a gmod server running i have hldsupdatetool and used it to get the gmod files.  I tried to launch the server useing a batch as such.
I:\Programs\HLServer\orangebox\srcds.exe -game garrysmod +sv_defaultgamemode "BoXDredead" +map zs_nastyhouse +hostname "GameBoXD|ReDead" +ip 192.168.1.101
The command box xlosed and server didnt appear so then i added pause to the end still didnt work so how could i run the server?
Im not going to use mserver it don't like me!
Oh and i dont have a server cfg file that ive been hearing about so info on this would be great.
Re: GMOD server help
« Reply #1 on: July 08, 2008, 10:09:28 am »
start I:\Programs\HLServer\orangebox\srcds.exe -game garrysmod +sv_defaultgamemode "BoXDredead" +map zs_nastyhouse +hostname "GameBoXD|ReDead" +ip 192.168.1.101
That should do the trick, just added "start" to the begining.
Offline Jarviar
« Reply #2 on: July 08, 2008, 10:57:17 am »
trying now and if this dont work im guna try armpits server thing.
Offline Jarviar
« Reply #3 on: July 08, 2008, 10:59:54 am »
it didnt appear in server list.
Wait i dont think it downloaded completely darn power outages.
EDIT: Re downloaded and it works.
« Last Edit: July 08, 2008, 01:01:31 pm by Jarviar »
« Reply #4 on: July 08, 2008, 04:05:01 pm »
Enjoy :D
Offline Jarviar
« Reply #5 on: July 08, 2008, 11:22:23 pm »
umm...
I host and it works for all my pcs but noone else can play i think it stuck on lan but i changed it to internet soo...
« Reply #6 on: July 09, 2008, 12:09:47 am »
Couple possibilities:
1: set sv_lan 0
2: Are you behind a firewall, if so which one?
3: Are you behind a router, if so which one?
Provide me with this information and we will get your server running :D
Offline Jarviar
« Reply #7 on: July 09, 2008, 11:53:27 am »
1. alright ill try
2. Turning off Windows firewall
3. Yes linksys but we haven't had problems with most things.
EDIT sv_lan 0 is set but its lan.
« Last Edit: July 09, 2008, 11:59:56 am by Jarviar »
« Reply #8 on: July 09, 2008, 12:39:30 pm »
Oh, you need to forward your port through your router, or enable DMZ. I recommend you just forward the ports though.
This will show you what to do
