Author Topic: Admin rights revoked/changed after a random server crash. (ULX)  (Read 5466 times)
Eklem
Hello. My server crashed not too long ago, out of the blue. After it came back online I no longer had my admin rights. I am the only superadmin, with one real life friend as an admin. That's all.
For some reason everything in the server files is still the same, but it does not show me as an admin or let me use ULX commands. Rcon + ULX commands work fine, I run 'rcon ulx adduser' and added myself into superadmin again. My health/armor shows up as it should, and my name colour, however I actually have no rights to access the menus.
I was just wondering if anybody could quickly help, I've done a brief search on the forums + on the net and didn't find anything to do with this problem, most of which were problems with the 'users.txt'.
Eklem
Re: Admin rights revoked/changed after a random server crash. (ULX)
« Reply #1 on: July 08, 2008, 01:07:28 pm »
Deleted my files and let the server re-create them, and it's worked. Sorry to bother you.
Offline Gmods
« Reply #2 on: July 16, 2008, 11:35:14 am »
Hi i'm getting this to and I don't want to have to keep re-uploading my files each time. Can someone tell me a way to fix it removing permissions after a reboot?
Offline Tophat Man
« Reply #3 on: July 16, 2008, 03:26:19 pm »
You just rejoin, the client side part of ulx seems to break every time a server is restarted.
Offline Gmods
« Reply #4 on: July 16, 2008, 03:50:53 pm »
I've tried the rejoining. But when I try to use my Admin panel I get "Unkown command ULX" and none of the commands work in console. The only way to solve it is to remove the files then re-upload them :/
Offline Tophat Man
« Reply #5 on: July 16, 2008, 05:58:53 pm »
Then you either installed ulx wrong or have some other unrelated problem that I don't know how to fix.
