Author Topic: ULib groups  (Read 9555 times)
ULib groups
« on: July 09, 2008, 08:36:40 pm »
What is the name of the table that the ULib groups are stored under?
==EDIT==
Found it in the defines.lua file.
« Last Edit: July 09, 2008, 08:41:34 pm by jay209015 »
Re: ULib groups
« Reply #1 on: July 09, 2008, 09:08:48 pm »
What I was looking for is a way to get a full list of allows for each group.
Re: ULib groups
« Reply #2 on: July 10, 2008, 04:26:24 pm »
You may have already found your answers, but I'll answer what I think it would be for anyone else that stumbles here.
ucl.groups[ <group_your_checking> ].allow
Pseudo-non checked lua code - I trust I'll be corrected.
for a, check_group in pairs (ucl.groups) do
    for b, each_allow in pairs ( ucl.groups( check_group ).allow ) do
-- Msg/Print/Whatever ( each_allow )
Re: ULib groups
« Reply #3 on: July 11, 2008, 01:06:29 am »
PrintTable(ucl.groups) returned nil :S
Re: ULib groups
« Reply #4 on: July 11, 2008, 04:59:33 am »
ULib.ucl.groups silly :P
Re: ULib groups
« Reply #5 on: July 11, 2008, 03:54:40 pm »
See, knew I'd be corrected!
I missed that ULib. detail. :P
Re: ULib groups
« Reply #6 on: July 11, 2008, 10:11:42 pm »
Is there a table that has the full list of allows, including the ones that are inherited? Like:
 Default, Superadmin has 16, Admin 80, and operator 1
Admin inherits from operator, and superadmin inherits from admin, so that means Superadmin really has 97 and admin has 81.
Right now I'm using this little script to do the job, just wondering if the was an easier way.
// UGroup
USort_Temp = 0
UGroups = {}
UpdateAllows = true
for k,v in pairs(ULib.ucl.groups) do
table.insert(UGroups, k )
UAllows = {}
for k,v in pairs(UGroups) do
UAllows[v] = #ULib.ucl.groups[v]["allow"]
UInherits = {}
function UpdateAllows()
UInherits[v] = ULib.ucl.groups[v]["inherit_from"]
if #UInherits[v] > 0 then
for k2,v2 in pairs(ULib.ucl.groups[v]["inherit_from"]) do
UAllows[v] = UAllows[v] + UAllows[v2]
if not UInherits[v2] == nil then
UpdateAllows = true
UpdateAllows = false
if UpdateAllows then
UpdateAllows()
UpdateAllows()
I'm working on a script so that you can type: UPromote <player>, and it will promote them to the next level :D
