Author Topic: GAMEMODE:AddNotify  (Read 6720 times)
GAMEMODE:AddNotify
« on: July 17, 2008, 01:29:00 pm »
I've been looking all over the garrysmod wiki, but have yet to find any documentation on this. I know it must be out there, because it's getting used a quite a few scripts. So, it would be greatly appreciated if someone could point in the right direction.
Re: GAMEMODE:AddNotify
« Reply #1 on: July 17, 2008, 01:41:48 pm »
« Reply #2 on: July 17, 2008, 04:18:42 pm »
Thank you, been looking for that for a while.
One more question, how do you make functions like you did with ULib ?
like
ULib.kick(ply, reason )
if I try and create a function with Dev.function( stuff here) it says
attempt to index global 'Dev' (a nil value)
==EDIT==
Looked into ULib's code and figured out that it was table, "Duh:S"  .
« Last Edit: July 17, 2008, 04:45:08 pm by jay209015 »
Offline Sc00by22
« Reply #3 on: July 24, 2008, 03:36:32 pm »
You could use this
function DisplayNotify(msg)
   local txt = msg:ReadString()
   GAMEMODE:AddNotify(txt, msg:ReadShort(), msg:ReadLong())
   -- Log to client console
   print(txt)
usermessage.Hook("_Notify", DisplayNotify)
