Author Topic: How do I make gcombat admin only?  (Read 4326 times)
Nerdygamer
« on: August 14, 2008, 01:21:20 pm »
Well I have a group on my server and i want them to have gcombat but I don't want users to use gcombat to. Is there a code I can use so I can do this?
Offline starstreak
Re: How do I make gcombat admin only?
« Reply #1 on: August 25, 2008, 10:44:26 pm »
I Own a server and noobs would destroy crap with it so i looked into it and figured it out using the command 'ulx tooldeny Gcombat' that will disable it but admins will get it run it every time server starts up
« Reply #2 on: August 26, 2008, 07:42:08 pm »
Not sure if you're asking or not, but, like our readme.txt points, you could copy the addons/ulx/cfg/server.ini to /gmod/cfg , then add "ulx tooldeny Gcombat" to the ini file.
