Author Topic: Console Commands are Broken, Re-installing ULX & Ulib doesn't fix it!  (Read 6334 times)
Offline Spykodemon
  • Lolwut?
Hey!
I have recently set up a 64 slot server for Garrys mod and I am having a very fustrating problem!
I recently installed ULX on my server, added a few admins to the users.txt list (The one In data/Ulib of course!), It went fine for 3 days and the next day, the console commands stopped working.
I didn't tamper with anything within the 3 days, the chat commands still work but the console ones still don't. I tried doing a command like 'rcon ulx help' and It worked, although the word 'ulx' didn't come up in the suggestions menu (The little menu which pops down when you partially enter a command in the console.)
Also to note:
When I join, it says '[UCL] Access set' Twice in the Chat box, In the console it also says 'Unhandled message 'UlibLuaFn', I am using the Latest SVN version of both ULX and Ulib, I also recently uninstalled ULX and Ulib and I decided to Re-install it again, Now it doesn't work!
I Re-installed the server Totally, Still, No avail.
Is there something i am doing wrong here?  ???
Re: Console Commands are Broken, Re-installing ULX & Ulib doesn't fix it!
« Reply #1 on: August 19, 2008, 01:48:11 pm »
Try deleting your data/ULib folder, restart the server, add yourself as superadmin through rcon, reconnect, and add everyone else you want to be admin in game with the standard ulx adduser command.
Even though it's possible, I do not suggest editing any of the ULib data file directly.
Offline Spykodemon
  • Lolwut?
« Reply #2 on: August 20, 2008, 11:37:45 am »
Well I tried everything you said above, When I add myself as superadmin via rcon, This comes up:
ulx/cl_lib.lua:5: attempt to call field 'umsgRcv' (a nil value)
Warning: Unhandled usermessage 'ulib_sound'
« Reply #3 on: August 20, 2008, 03:58:18 pm »
At server start, are there any errors from ULib or ULX, besides possible usermessage errors?
The problems you're having seem much like an old version we had, not one with the recent SVN.
You say you edited users.txt, 3 days later, problems.
Did you restart the server after editing the users.txt, or, did it crash/manually get restarted 3 days later?
Offline Spykodemon
  • Lolwut?
« Reply #4 on: August 29, 2008, 04:19:57 am »
Sorry I didn't reply, I was on Holiday  ::)
There is nothing related to ULX or Ulib in th Server console as far as I can see.
Yes I restarted the server after editing users.txt
Offline Spykodemon
  • Lolwut?
« Reply #5 on: August 29, 2008, 10:01:37 am »
I am also starting to think this isn't a ULX/Ulib problem, There are also some SWEP's and Stools which only work for some people, and The server forces you to download all the addon files and such even though we have a sv_downloadurl working And it's totally up to date.
Although this may not be a Ulib problem, Help for this problem would be appreciated too!
« Reply #6 on: August 29, 2008, 12:28:55 pm »
On your sv_download url, did you upload your servers cache too?
Offline Spykodemon
  • Lolwut?
« Reply #7 on: August 30, 2008, 10:31:10 am »
No I didn't : :-X
I just uploaded it and it's working great now!
Thanks alot!
