Author Topic: Another server, another help thread.  (Read 6189 times)
Offline Pantho
« on: August 21, 2008, 03:43:03 pm »
ULX/ULIB installed as well as Uteam and sui_scoreboard.
This all works fine on my other server, i copied my groups and users from there. They both work.
Problem is uteam simply wont work
the 2 files are installed correctly :s any ideas?
(btw its running sb3)
« Last Edit: August 21, 2008, 04:04:13 pm by Pantho »
Offline Pantho
Re: Another server, another help thread.
« Reply #1 on: August 21, 2008, 04:16:15 pm »
Problem 2:
I had to re-install Gmod, but i used an old backup because my internet is limited at home .
So, its all updated, everything works.. But ulx console commands
] ulx slay example
] ulx slay pantho
] this isnt a command
Unknown command: this
See my problem, ulx console commands wont work, but...
ByB | Pantho: !god pantho
(ADMIN) ByB | Pantho granted god mode to ByB | Pantho
Warning: Unhandled usermessage 'ulib_sound'
this is across both my servers since i re-installed. Ideas?
« Reply #2 on: August 21, 2008, 04:32:47 pm »
Looks like you don't have the sv_downloadurl set up correctly on issue #2.
Offline Pantho
« Reply #3 on: August 21, 2008, 06:32:32 pm »
Well, its the same downloadurl as i had before i re-installed gmod. Clientside re-install i might add...
allowdownload is all set, its downloading all lua to lua_temp as it should.
www.bybservers.com/gmod is the downloadurl if you care to check :(
Thanks for input but don't see how its that, considering its since i did a clientside re-install.
-edit
Just to clarify, this is a dedicated server on an external box.
The reinstall was completly client side, i had to remove ls2/rd2 and it wasnt letting me.
-edit2
Ok, I just tried to fix myself with playing with lua files, know its totally screwed, im going to put Problem2 down to a bad install and do a full download overnight, it shouldnt hurt my bandwidth to much, long as i backup my addons. (Problem 2 fixed,gnight :))
So just problem1 ;)
« Last Edit: August 21, 2008, 07:24:08 pm by Pantho »
« Reply #4 on: August 21, 2008, 07:02:16 pm »
Someone else around here had issue with SB3 and UTeam.
I have NO idea what the true title of the game mode actually ended up being as someone from the SB3 forum ended up helping them, but I'm pretty sure it was because the 'gamemode' section of Uteams config file didn't contain the proper SB3 gamemode name.
Offline Pantho
« Reply #5 on: August 25, 2008, 08:04:43 am »
thanks jamminr ill look into that :)
Offline Pantho
« Reply #6 on: August 26, 2008, 06:27:36 am »
Fixed :)
Forgot to set the uteam settings for gamemode ...
<-- dunce thanks
