Author Topic: Motd trouble  (Read 7974 times)
Offline shadowedge
Motd trouble
« on: August 24, 2008, 08:47:20 am »
When ever i change my Motd in  the garrysmod/data/ulx directory it always changes back to default? any help please
Re: Motd trouble
« Reply #1 on: August 24, 2008, 11:47:08 am »
Never edit addons files. I believe our readme states this.
motd.txt should be created/modified from the root gmod folder.
Offline shadowedge
Re: Motd trouble
« Reply #2 on: August 24, 2008, 12:23:55 pm »
can you please explain a little more in depth
Re: Motd trouble
« Reply #3 on: August 24, 2008, 02:35:12 pm »
<your drive letter>:\<Place you installed Steam>\<your username>\orange box\<gmod folder>\motd.txt
Offline shadowedge
Re: Motd trouble
« Reply #4 on: August 25, 2008, 12:16:15 pm »
to me there is no orange box directory folder
Re: Motd trouble
« Reply #5 on: August 25, 2008, 03:08:55 pm »
Which version of Gmod are you running???
Though I guess it's possible, I've not seen a client or server installation of Gmod without an Orange Box folder in the past year or so.
Still, whatever folder your gmod is installed into, the folder before addons or data or settings or cfg, is your root gmod folder.
Offline shadowedge
Re: Motd trouble
« Reply #6 on: August 30, 2008, 01:10:41 pm »
so the file should be at C:\Program Files (x86)\Steam\steamapps\<name>\garrysmod\garrysmod\motd.txt
Re: Motd trouble
« Reply #7 on: August 30, 2008, 02:21:00 pm »
Right
Re: Motd trouble
« Reply #8 on: August 30, 2008, 07:06:28 pm »
Right
If a listen server, yes.
If a dedicated, there _should_ be an orangebox folder, right?
Can anyone else shed light on this? I could have sworn hldsupdatetool installs an orangebox folder and puts garrysmod into that when installing a dedicated server.
In my dedicated server folders its <path I store hlds.exe>\orangebox\garrysmod\motd.txt
Offline Tophat Man
Re: Motd trouble
« Reply #9 on: August 31, 2008, 01:27:08 am »
I think shows orange box instead of a username for servers. orangebox\garrysmod instead of <name>\garrysmod
Reiko
Re: Motd trouble
« Reply #10 on: September 29, 2008, 12:13:18 am »
Yep. Every dedicated server I've ever run has been;
(hlds.exe folder)/orangebox/garrysmod/etc...
