Author Topic: MOTD to Whatever menu. Help?  (Read 8665 times)
Offline Frostyfrog
« on: September 23, 2008, 04:56:28 pm »
Hi, I was just wondering if you guys could help me turn the MOTD menu into my own menu. I'm kind of new to lua yet I want to add some of my own menus to to a few servers that I'm the lua scripter for. Please help me. :)
Re: MOTD to Whatever menu. Help?
« Reply #1 on: September 23, 2008, 04:57:28 pm »
I don't understand what you're seeking?
Offline Frostyfrog
« Reply #2 on: September 23, 2008, 05:10:15 pm »
I am trying to get something similar to the MOTD script, but keep it separate. I'm currently trying to make a donator menu (I would do the HTML for it). It would work just like the MOTD. (I haven't tried links yet though).
The file I am trying to make a copy of and edit is: \addons\ULX\lua\ulx\modules\cl\motdmenu.lua
I Have no idea how to make this thing work :(
« Reply #3 on: September 23, 2008, 06:16:20 pm »
Do you mean display different HTML pages depending on what command was used?
Or do you mean an actual GUI menu in game, like "ulx menu" or "!menu"?
We, well, I, am totally lost as to what you are looking for.
Offline Frostyfrog
« Reply #4 on: September 23, 2008, 06:37:45 pm »
Something like this (my script):
local HTML = {}
function HTML:StatusChanged( text )
function HTML:ProgressChanged( progress )
function HTML:FinishedURL( url )
function HTML:OpeningURL( url, target )
vgui.Register( "frostyDonator", HTML, "HTML" )
function frosty.showDonatorMenu()
local window = vgui.Create( "DFrame" )
window:SetSize( ScrW()*0.9, ScrH()*0.9 )
window:SetSize( 640, 480 )
window:Center()
window:SetTitle( "Donation Menu" )
window:SetVisible( true )
window:MakePopup()
local html = vgui.Create( "frostyDonator", window )
local button = vgui.Create( "DButton", window )
button:SetText( "Close" )
button.DoClick = function() window:Close() end
button:SetSize( 100, 40 )
button:SetPos( (window:GetWide() - button:GetWide()) / 2, window:GetTall() - button:GetTall() - 10 )
html:SetSize( window:GetWide() - 20, window:GetTall() - button:GetTall() - 50 )
html:SetPos( 10, 30 )
html:SetHTML( file.Read( "Frostymod/Donator.txt" ) )
usermessage.Hook( "SendDonatorMenu", frosty.showDonatorMenu )
function frosty.rcvDonatorStart( um )
frosty.DonatorContent = ""
usermessage.Hook( "frostyDonatorStart", frosty.rcvDonatorStart )
function frosty.rcvDonatorEnd( um )
file.Write( "frosty/Donator.txt", frosty.DonatorContent )
frosty.DonatorContent = nil
usermessage.Hook( "frostyDonatorEnd", frosty.rcvDonatorEnd )
function frosty.rcvDonatorText( um )
frosty.DonatorContent = frosty.DonatorContent .. um:ReadString()
usermessage.Hook( "frostyDonatorText", frosty.rcvDonatorText )
CreateConVar( "frostydonation_opentype", "F4", FCVAR_ARCHIVE )
local function CheckKeys()
if ( menu:IsVisible() ) then return end
// If the chat's open we don't want anything triggering when we type.
if ( chatOpen ) then
if ( frostydonation.KEY && ( frostydonation.KEY < KEY_F1 || frostydonation.KEY > KEY_F12 ) ) then return end
RunString( "frostydonation.KEY = KEY_" .. string.upper( GetConVarString( "frostydonation_opentype" ) ) )
if ( input.IsKeyDown( frostydonation.KEY or KEY_F4 ) ) then
RunConsoleCommand( "frostydonation" )
return
MOTD File:
local HTML = {}
vgui.Register( "ULXMotd", HTML, "HTML" )
function ulx.showMotdMenu()
window:Center()
window:SetTitle( "ULX MOTD" )
window:MakePopup()
local html = vgui.Create( "ULXMotd", window )
html:SetHTML( file.Read( "ulx/motd.txt" ) )
usermessage.Hook( "SendMotdMenu", ulx.showMotdMenu )
function ulx.rcvMotdStart( um )
ulx.motdContent = ""
usermessage.Hook( "ULXMotdStart", ulx.rcvMotdStart )
function ulx.rcvMotdEnd( um )
file.Write( "ulx/motd.txt", ulx.motdContent )
ulx.motdContent = nil
usermessage.Hook( "ULXMotdEnd", ulx.rcvMotdEnd )
function ulx.rcvMotdText( um )
ulx.motdContent = ulx.motdContent .. um:ReadString()
usermessage.Hook( "ULXMotdText", ulx.rcvMotdText )
addons\ULX\lua\ulx\modules\menus.lua:
if file.Exists( "../lua/ulx/modules/cl/motdmenu.lua" ) then
CreateConVar( "motdfile", "ulx_motd.txt" )
function ulx.cc_motd( ply, command, argv, args )
if not ply:IsValid() then
Msg( "You can't see the motd from the console.\n" )
return
if not file.Exists( "../" .. GetConVarString( "motdfile" ) ) then return end -- Invalid
umsg.Start( "SendMotdMenu", ply )
umsg.End()
ulx.concommand( "motd", ulx.cc_motd, " - Shows you the message of the day.", ULib.ACCESS_ALL, "!motd", _, ulx.ID_HELP )
local function showMotd( ply )
if not util.tobool( GetConVarString( "ulx_showMotd" ) ) then return end
if not ply:IsValid() then return end -- They left, doh!
local f = file.Read( "../" .. GetConVarString( "motdfile" ) )
umsg.Start( "ULXMotdStart", ply )
umsg.End()
while f:len() > 0 do
umsg.Start( "ULXMotdText", ply )
umsg.String( f:sub( 1, 240 ) )
umsg.End()
f = f:sub( 241 )
umsg.Start( "ULXMotdEnd", ply )
umsg.End()
umsg.End()
hook.Add( "ULibPlayerULibLoaded", "showMotd", showMotd )
ulx.convar( "showMotd", "1", " - Shows the motd to clients on startup.", ULib.ACCESS_ADMIN )
« Last Edit: September 23, 2008, 06:43:55 pm by Frostyfrog »
« Reply #5 on: September 23, 2008, 06:56:51 pm »
See our releases section, UMotd
It does what you want, allows you to create any html page besides (or including) a MOTD.
