Poll
Yes, Much Better!
71 (59.7%)
Yeah
22 (18.5%)
14 (11.8%)
No
4 (3.4%)
I Prefer The Old GUI
8 (6.7%)
Total Members Voted: 1
Re: URestrict
« Reply #105 on: June 30, 2009, 10:00:18 am »
Revision: 18
Author: jay
Date: 11:55:41 AM, Tuesday, June 30, 2009
Message:
Removed useless functions and hooks
Modified : /info.txt
Modified : /lua/ULib/modules/server/URestrict.lua
Re: URestrict
« Reply #106 on: June 30, 2009, 10:17:48 am »
Revision: 19
Author: jay
Date: 12:17:09 PM, Tuesday, June 30, 2009
Message:
GUI now loads all items on initial startup
Umsgs send on time
Stability increases
Modified : /lua/ULib/modules/client/URestrict_cl.lua
Offline Dv2236
    • MyGamingVoid
Re: URestrict
« Reply #107 on: June 30, 2009, 10:40:38 am »
Thanks for the updates, love this addon and always like it better :)
Re: URestrict
« Reply #108 on: June 30, 2009, 10:51:40 am »
     - No problem, and thank you for your interest in the script.
Revision: 20
Author: jay
Date: 12:50:15 PM, Tuesday, June 30, 2009
Message:
New ConCommand URestrict_Help
Added : /lua/ULib/modules/client/URestrict_Help.lua
Offline fang64
Re: URestrict
« Reply #109 on: July 02, 2009, 05:28:39 am »
I spotted a problem, and it may be with my configuration but...
Lua Error: ERROR: Hook 'URestrict_Loadout_Hook' Failed: ULib/modules/server/URestrict.lua:153: attempt to index global 'URestrict_loadout' (a nil value)
Lua Error: Removing Hook 'URestrict_Loadout_Hook'
I can provide more info if needed
Apparently this only happens if the client blocks the URestrict_cl.lua from downloading so there needs to be a way to enforce the client even if he blocks the download of the dua cache. just an observation.
« Last Edit: July 02, 2009, 05:49:40 am by fang64 »
Re: URestrict
« Reply #110 on: July 02, 2009, 08:35:10 am »
That is interesting, but this part of the script is all server side.
==EDIT==
Forgot to ask: Are you running the latest svn version? Revision 20?
« Last Edit: July 02, 2009, 10:19:51 am by jay209015 »
Offline fang64
Re: URestrict
« Reply #111 on: July 02, 2009, 04:39:09 pm »
yes I just updated, I also need to mention I am having a problem with users dropping weapons in the game. I'm being forced to grab the weapons up when this occurs.
I'm not sure if it's one of my scripts or just a side effect of one of yours I am going to try and narrow it down again but it only seems to occur with URestrict.
Re: URestrict
« Reply #112 on: July 02, 2009, 06:53:20 pm »
What do you mean? My script disables the ability for users without the permission to use the weapons from picking them up as well.
Offline lavacano201014
Re: URestrict
« Reply #113 on: July 02, 2009, 10:01:09 pm »
After you fix the weapon pickup bug, could you set it up so users are allowed to have weapons, but do not spawn with them? Like that other guy was wanting. Here's what we mean:
Let's say I have a SWep called the Cake Shooter. It shoots the cake model from Portal. I want everyone to have access to it. Currently, if I set it up as good in URestrict, it makes them spawn with it, which I do not want. I want only me to spawn with it, even if everyone else can get it through the weapons tab.
Re: URestrict
« Reply #114 on: July 02, 2009, 10:12:07 pm »
...could you set it up so users are allowed to have weapons, but do not spawn with them?
     - Sure, that's do-able I suppose. I'll work on it real quick and try to get it updated in a few minutes.
Re: URestrict
« Reply #115 on: July 02, 2009, 11:00:53 pm »
Revision: 21
Author: jay
Date: 12:59:42 AM, Friday, July 03, 2009
Message:
Fixed Players Not Being Able To Pick Up Allowed Weapons
Made It So That Not All Allowed Weapons Are Given To The Player On Spawn
Offline fang64
Re: URestrict
« Reply #116 on: July 03, 2009, 02:59:17 pm »
I think I found part of the issue within one of my lua modules, at least I thought. I'm going to update to the latest revision and see if the weapons still fly out of a playing at spawn. I apparently didn't describe the behavior correctly.
Player spawns, and the game attempts to give them the default weapon set gmod uses, which then causes URestrict to prevent the player form picking up spawned weapons. A sudden bundle of weapons comes flying
out of the player spawn. This occurs each time a player joins. I have cleaned up my server install and it was
still happening before revision 20, I updated to the latest ( from my last post ). I am not going to update to the latest to see if it is fixed. inadvertently
The Loadout UI is not functioning nor is the weapon restrictions now on my server I am checking to see if it's a conflicting script but so far no leads to why the restrictions are not functioning I will do a wipe down of all addons again and reduce it down to URestrict, ULX/Ulib again to see what is causing the issue.
There seems to be some interaction with gcombat and your URestrict script now. That was causing the loadout to fail in the latest revisions maybe hook overriding?
« Last Edit: July 04, 2009, 02:57:00 pm by fang64 »
Re: URestrict
« Reply #117 on: July 05, 2009, 05:40:58 pm »
     -Revision 21 fixes that.
     - I'm not seeing this problem, and I don't believe there is a conflicting hooks, because all mine are unique.
Offline Tom
Re: URestrict
« Reply #118 on: July 06, 2009, 12:54:18 am »
Are you just keeping us updated? or are you actually releasing these things every time?
Re: URestrict
« Reply #119 on: July 06, 2009, 07:06:19 am »
releasing everytime
