Poll
Yes, Much Better!
71 (59.7%)
Yeah
22 (18.5%)
14 (11.8%)
No
4 (3.4%)
I Prefer The Old GUI
8 (6.7%)
Total Members Voted: 1
Re: URestrict
« Reply #150 on: July 12, 2009, 08:49:07 pm »
Ok, looked into your "error" with a little more detail, and it appears your using this addon:
http://www.garrysmod.org//downloads/?a=view&id=58283
And after looking into the addons lua/weapons folder I realized you missnamed all the weapons, hence the errors.
Weapon names are exactly the same as the names of the folder here:
...\addons\RCS\lua\weapons
EX:
"weapon_physgun"
"weapon_physcannon"
"gmod_tool"
"gmod_camera"
"weapon_crowbar"
"weapon_stunstick"
"weapon_ar2"
"weapon_frag"
"weapon_crossbow"
"weapon_alyxgun"
"weapon_pistol"
"weapon_rpg"
"weapon_shotgun"
"weapon_smg1"
"weapon_slam"
"rcs_deagle"
"rcs_elites"
"rcs_57"
Offline Jethro
Re: URestrict
« Reply #151 on: July 13, 2009, 06:46:07 am »
Hi,
I checked the addons folder and just to confirm I am using this addon: http://www.garrysmod.org/downloads/?a=view&id=62657 rather than the "RCS" addon.
I have checked the ...\addons\CSS Realistic Weapons 4.0\lua\weapons
Screenshot:
http://img6.imageshack.us/img6/7986/picturek.png
I believe i am using the right names =/
Console code
] ulx ent weapon_real_cs_p90   //This spawned a weapon which I could not pick up but shows that i have named the weapons correctly.
] ulx ent weapon_mispeltweaponname    //This obviously didint spawn a weapon and returened an error
Attempted to create unknown entity type weapon_mispeltweaponname!    //Error Returned
I don't know what to do from here on. Is anyone else having these problems when adding custom non HL2 weapons?
Offline bennie900
Re: URestrict
« Reply #152 on: July 14, 2009, 04:06:32 am »
I have recived a new error. This happens when I join the server in the console.
[ULIB] Loading CLIENT module: urestrict_cl.lua
[ULIB] Loading CLIENT module: urestrict_help.lua
Warning: Unhandled usermessage 'URestrict_Tools'
Warning: Unhandled usermessage 'URestrict_Loadouts'
Warning: Unhandled usermessage 'URestrict_Loadout_Groups'
Warning: Unhandled usermessage 'URestrict_Loadout_Exclusions'
Warning: Unhandled usermessage 'URestrict_Loadout_Loadout'
Warning: Unhandled usermessage 'URestrict_All_Groups'
When I go to type "URestrict" to bring the menu up it says "Unknown Command"
] URestrict
Unknown Command: 'URestrict'
Re: URestrict
« Reply #153 on: July 14, 2009, 10:45:43 am »
Warning: Unhandled usermessage 'URestrict_Tools'...'
] URestrict
What revision are you running?
Offline bennie900
Re: URestrict
« Reply #154 on: July 14, 2009, 01:40:00 pm »
27, the latest, but I have reverted back to 25 for now.
Offline Jethro
Re: URestrict
« Reply #155 on: July 14, 2009, 03:04:39 pm »
Lucky you, Version 25 doesn't work for me either.
Had to just exclude all groups from loadout restrictions.. :(
Any luck in figuring out whats causing my loadout errors yet?
Re: URestrict
« Reply #156 on: July 14, 2009, 07:22:34 pm »
     - Working on that now.
     - You should stick with the latest version.
Re: URestrict
« Reply #157 on: July 14, 2009, 08:03:45 pm »
Jethro, I tested it with the addon you showed you had, and with your configurations you had set for URestrict, and I did not get those errors. I spawned with the weapons as I should. Do you have CS:S installed in your steam and on your server, unless you are running it in single player or a listen server, then just steam?
Bennie, the only thing I can suggest is to check your server console for more errors pertaining to URestrict, or delete URestrict and install a fresh copy with svn.
« Last Edit: July 14, 2009, 08:42:35 pm by jay209015 »
Offline Jethro
Re: URestrict
« Reply #158 on: July 15, 2009, 11:54:31 am »
Both me and my server has the CSS game intergrated but the pack doesn't work on either single player or on rented server. I suppose ill have to stick to HL2 weapons for now. Thanks for taking a look anyway :p
Jet
Re: URestrict
« Reply #159 on: July 15, 2009, 12:36:42 pm »
     - I really wish I could figure out what it was causing that conflict, but I can't think of anything unless the weapons aren't initializing before URestrict. Have you tried respawning and see if it spawns you with the weapons then?
Offline Jethro
Re: URestrict
« Reply #160 on: July 15, 2009, 01:11:11 pm »
Yes I have tried slaying myself and that doesn't give you the defined weapons either.
Offline wishbone
Re: URestrict
« Reply #161 on: July 15, 2009, 01:27:55 pm »
Could be the no pickup hook.
Re: URestrict
« Reply #162 on: July 15, 2009, 09:36:01 pm »
     - Nope, it's saying the entities don't exist when he spawns. He can pick them up just fine.
     - That's just weird, since the ulx ent command works =/
Offline Jethro
Re: URestrict
« Reply #163 on: July 16, 2009, 09:13:45 am »
Possible new feature: It would make it a lot easier to add tool names to the menu if Urestrict was capale of checking if the tool exists on the server when you click "Add".
Currently for example you can add the tool "drone_launcher" from stargate or "gmod_laser" for The LaserStool2.0 and it will not block their use... yet when you use the remover tool on them it tells you:
Code: Text
  1. [AGC] Jethro Jones removed drone_launcher
  2. [AGC] Jethro Jones removed gmod_laser
  3.
And yes I have tired diffrent names such as "laser, drone, LaserEffect, launcher" etc
If this implementation was possible it would save me time from having to test each tool when I add one.
Thanks
Jethro
Re: URestrict
« Reply #164 on: July 16, 2009, 10:49:06 am »
     - Yes, I am planning on implementing this very soon, but atm the moment the easiest way o find the correct name of a tool is to select the tool, and go into the console and type gmod_tool, and it'll autocomplete the actual name.
