Poll
Yes, Much Better!
71 (59.7%)
Yeah
22 (18.5%)
14 (11.8%)
No
4 (3.4%)
I Prefer The Old GUI
8 (6.7%)
Total Members Voted: 1
Re: URestrict
« Reply #195 on: July 31, 2009, 07:57:02 am »
Kennis, though we understand your suggestion, making it easier for server owners is allready being done.
Having to give the rights for URestrict to each individual person, rather than just giving the admin group, would for most people be more difficult.
As I've stated before, admin and superadmin access are sacred.
ULib allows for many other custom group creations that could in many ways mimic ULX admin access, without giving someone admin access.
Jay may find a compromise, but I personally don't believe removing the IsAdmin check would make it easier for all.
[Edit] - Jay, perhaps using "ucl.query" along with the IsAdmin checks might work. This way, adding URestrict to the denies of any player would, in theory, prevent them from using the control panel functions. My only concern would be which functions to prevent changes to. You'd still want them to be able to allow friends to touch thier own items of course. I figure you probably already have that set up though.
« Last Edit: July 31, 2009, 08:05:56 am by JamminR »
Offline Flinta
Re: URestrict
« Reply #196 on: August 01, 2009, 04:22:36 am »
I add paint tool, on urestrict list, but it doesnt block it. people can still use paint.. bug or?
Offline bennie900
Re: URestrict
« Reply #197 on: August 01, 2009, 04:52:33 am »
I also have this, I'm guessing the paint tool is retarded compared to other tools.
Offline Jethro
Re: URestrict
« Reply #198 on: August 03, 2009, 04:44:26 pm »
Bug found: My custom loadouts are not working for any of the groups. It only gives them the "default.txt" loadout and 2 other custom weapons. No errors are being displayed.
Have spent another 6 hours or so trying to fix this bug on my client and on the rented server with no success. I have even tried other counter strike weapons addons but they have the same problem.
When you set up custom loadouts for all of your groups with Urestrict using certain SWEPS:
You spawn with your HL2 weapons and only one/two of the Custom CSS weapons.
Just wondering if anyone has encountered this problem yet as Jay was unable to replicate it?
I'm going to have to go back to HL2 weapons till/if I find a fix.
Addons that i have tried:
RealCS v7 (CSS weapons) --> You spawn with a "rcs_beretta"
CSS Realistic Weapons 4.0 --> You spawn with a "weapon_real_cs_ump_45"
PS: Also gives you the same error when trying using Stargate weapons
Example Error:
Code: Text
  1. Updated DuaFiles (4899)
  2. Attempted to create unknown entity type weapon_real_cs_desert_eagle!
  3. NULL Ent in GiveNamedItem!
  4. Attempted to create unknown entity type weapon_real_cs_mp5a5!
  5. NULL Ent in GiveNamedItem!
  6. Attempted to create unknown entity type weapon_real_cs_smoke!
  7. NULL Ent in GiveNamedItem!
  8. Attempted to create unknown entity type weapon_real_cs_flash!
  9. NULL Ent in GiveNamedItem!
  10. Attempted to create unknown entity type weapon_real_cs_grenade!
  11. NULL Ent in GiveNamedItem!
  12. Attempted to create unknown entity type weapon_real_cs_xm1014!
  13. NULL Ent in GiveNamedItem!
  14. Attempted to create unknown entity type weapon_real_cs_pumpshotgun!
  15. NULL Ent in GiveNamedItem!
  16. Attempted to create unknown entity type weapon_real_cs_p90!
  17. NULL Ent in GiveNamedItem!
  18. Attempted to create unknown entity type weapon_real_cs_scout!
  19. NULL Ent in GiveNamedItem!
  20. Attempted to create unknown entity type weapon_real_cs_awp!
  21. NULL Ent in GiveNamedItem!
  22. Attempted to create unknown entity type weapon_hand_device!
  23. NULL Ent in GiveNamedItem!
  24. Attempted to create unknown entity type weapon_dexgun!
  25. NULL Ent in GiveNamedItem!
  26. Attempted to create unknown entity type sodan_cloak!
  27. NULL Ent in GiveNamedItem!
  28. Attempted to create unknown entity type weapon_staff!
  29. NULL Ent in GiveNamedItem!
  30. Attempted to create unknown entity type weapon_zat!
  31. NULL Ent in GiveNamedItem!
  32. weapons/ep2snip_base/shared.lua:647: attempt to call method 'SprintEnable' (a nil value)
  33. Attempted to create unknown entity type weapon_jihadbomb!
  34. NULL Ent in GiveNamedItem!
  35.
Hopfully its not just me XD
Thanks
Jethro
« Last Edit: August 04, 2009, 08:58:45 am by Jethro »
Re: URestrict
« Reply #199 on: August 03, 2009, 06:20:16 pm »
Just throwing out a wild hair theory...it's possible ULib/Urestrict are initializing before the CS Sent mods are.
Offline mishappp
Re: URestrict
« Reply #200 on: August 03, 2009, 08:29:42 pm »
Im trying to setup my darkrp server with ULX because it is the best admin plugin out im trying to run it with Urestrict, so I can give people tool gun privileges but im having the problem of keys pockets etc not being able to spawn with the person, I dont want to add it to the usergroup because if they switch to Combine police they wont be able to get stunstick arrestbaton etc, I have seen this work on other darkrp servers but I just cannot get this to work on mine, im extremely new to this process fyi so go easy on me.
Re: URestrict
« Reply #201 on: August 05, 2009, 11:03:19 am »
     - You have to add keys and pockets to the default_spawn.txt in order for them to be given to the player on spawn.
Offline mishappp
Re: URestrict
« Reply #202 on: August 05, 2009, 10:12:22 pm »
Yes but when they switch to combine police etc they will not have the arrest baton or anything else.
Offline atomicspark
Re: URestrict
« Reply #203 on: August 06, 2009, 08:35:29 pm »
Before I had to find some obscure command to disable STools (sents and weapons are easy). I recently gave up trying to find said command again and decided to try this. I must say, it works pretty well. Although I haven't bothered to try to figure out the Loadout tab. :P
Re: URestrict
« Reply #204 on: August 07, 2009, 10:45:34 am »
     - Just add everything that you need to allow people to spawn with inside the default spawn
Offline mishappp
Re: URestrict
« Reply #205 on: August 07, 2009, 12:24:11 pm »
That did not work everyone spawns with all the weapons.
Re: URestrict
« Reply #206 on: August 07, 2009, 02:10:52 pm »
If the weapon is not in the default_spawn.txt they will not spawn with it. Also if the weapon is not in their groups loadout, they will not spawn with it nor be able to pick it up. Sounds like you don't have you configurations properly set.
Offline Euphytose
  • I love Lemonade!
Re: URestrict
« Reply #207 on: August 10, 2009, 09:51:58 am »
Could someone download it for me and post it there? I don't want to download the SVN client because it messes up my right click menu after installed.
Offline gamerlv
  • VP of GAmers4Life
    • The awsome gamers4life clan site
Re: URestrict
« Reply #208 on: August 10, 2009, 10:19:39 am »
checked out and exported. Revision 30
Offline Euphytose
  • I love Lemonade!
Re: URestrict
« Reply #209 on: August 10, 2009, 12:51:10 pm »
Thanks a lot. :D
