Poll
Yes, Much Better!
71 (59.7%)
Yeah
22 (18.5%)
14 (11.8%)
No
4 (3.4%)
I Prefer The Old GUI
8 (6.7%)
Total Members Voted: 1
Offline MaMuS
Re: URestrict
« Reply #645 on: August 03, 2010, 09:49:28 am »
I would like to note that there is something funky with the svn. The newer revision misses the main URestrict.lua file, and ulib directory still has uppercase characters.
Re: URestrict
« Reply #646 on: August 03, 2010, 07:34:03 pm »
Yeah, something crazy happened, and it won't let me lowercase the ULib directory.
Re: URestrict
« Reply #647 on: August 03, 2010, 07:51:21 pm »
If you're in Windows, case doesn't matter. Either use a real O/S (like Linux) or rename the folder to something like ulib2 and then rename it again to ulib. :P
Re: URestrict
« Reply #648 on: August 03, 2010, 07:59:44 pm »
Or, fall back on old command shell, even WinXP one, where you can x:\blah\addons> ren ULib "ulib"
Should work for you. Did for me in testing.
Though a real OS is usually the preferred way, linux doesn't yet cut it Windows DX9,10 level gfx wise, and, well, Apple's bloated version of linux is just too expensive.
M$ has DX. Love hating them for that.
Re: URestrict
« Reply #649 on: August 03, 2010, 08:07:13 pm »
Haha, good old windows bashing :P
Re: URestrict
« Reply #650 on: August 03, 2010, 08:18:56 pm »
That'll rename it locally, but SVN still won't recognize that anything changed. Or at least, it didn't when I was doing renaming.
Re: URestrict
« Reply #651 on: August 03, 2010, 08:56:21 pm »
Ah, so it's more tortoise's way of reading the Windows dir structure more so than actual Windows not seeing it lowercase.
:P
(I know I know, to-mae-toh to-mah-toh) :D
Offline MaMuS
Re: URestrict
« Reply #652 on: August 04, 2010, 05:50:37 am »
If you really need a "True Unix shell" in windows, try Cygwin. You can then issue:
cd .../urestrict/lua/
svn-move ./ULib ./ulib
which is the proper way to rename/move things around with svn.
Also, if you need DX9 in Linux, try crossover and a nvidia card. :)
Offline saintwubbles
Re: URestrict
« Reply #653 on: August 04, 2010, 07:21:11 am »
Does anyone have a fix for the missing file?
Offline MaMuS
Re: URestrict
« Reply #654 on: August 04, 2010, 12:15:13 pm »
use the older revision:
svn checkout -r 33 http://ulyssesmod.net/URestrict/
Re: URestrict
« Reply #655 on: August 04, 2010, 08:05:00 pm »
should be fixed in revision 35, only thing I couldn't make windows do is change the ULib directory to ulib, everything else worked.
Offline robdog121
Re: URestrict
« Reply #656 on: August 04, 2010, 08:41:35 pm »
hey
ok well i tried with the linux server and it stil not working. i tried chaning folder name, but didnt help, i didnt edit the files though.
MaMuS could u upload or give me a link to download the files etc ur using (with jays permisssion of course :P)
EDIT*******
DONT WORRY I FIXED IT :P it loaded.
« Last Edit: August 04, 2010, 08:50:50 pm by robdog121 »
Offline robdog121
Re: URestrict
« Reply #657 on: August 04, 2010, 08:42:41 pm »
sorry, also jay i dunno how svn works, but do u have to delete the actual ULib directory off the svn thing then re add it but as ulib and then add the files.... just a suggestions im unsure how it works.
Re: URestrict
« Reply #658 on: August 04, 2010, 09:00:48 pm »
Revision 36: (Non Functional)
ULib folder deleted
Revision 37: (No Way For Me To Test. Could Someone Let Me Know If It's Working?)
ulib folder added
Offline robdog121
Re: URestrict
« Reply #659 on: August 04, 2010, 11:28:16 pm »
will test now
***edit***
WORKED (well ddownloaded properly) its deleted ULib and added ulib
THANKS
going to test on server now.
***edit (again) :P***
WORKED, well done.
umm anyone who is using this and trying to run on a darkrp server two things u need to do,
one: disable loadout thing for all groups. and this allows players to recieve there class weapons eg keys, arrest, unarrest, ram, med kit etc
and
two: remove the give sweps lua file in the ulib/modules or something. and this stops ppl from spawning weapons.
« Last Edit: August 04, 2010, 11:38:10 pm by robdog121 »
