Author Topic: Having a few problems  (Read 7108 times)
Offline Katie
  • Geek Girl
« on: September 30, 2008, 07:18:31 pm »
I'm having some issues with my server. I can't figure out how to get is VAC-Secure. I got everything else set up but VAC... Can anyone help me? I have everything is the right place and my settings for ULX and the server but why not VAC?
"I am your shield I am your sword. Mainly because I have all the weapons and the only key to the armory and YOOOOOU don't!"
Re: Having a few problems
« Reply #1 on: September 30, 2008, 07:59:11 pm »
VAC is enabled by default, if not add: -insecure 0    to your startup command.
« Reply #2 on: September 30, 2008, 08:26:08 pm »
Is this for a Gmod server?
I really didn't think Gmod needed VAC.
Sure, might help keep out cheaters that would use aimbot apps and modified Steam files for CSS and other games, but Ive not heard of any applications like that written for Gmod.
Lua aimbots maybe, but not actual compiled apps and modified files.
Then again, I'm not in the loop like I used to be. Loopy perhaps, but not in the loop.
Also, I think VAC has to have a special port forwarded for Steam/hlds to call home to mom for security.
If Jay's fix doesn't work, let us know or look at the steam support site 'what ports need to be forwarded?'
« Last Edit: September 30, 2008, 08:28:19 pm by JamminR »
« Reply #3 on: October 01, 2008, 03:29:19 am »
Is this a windows or Linux server? Got anything else running on the machine?
Otherwise, I'd have to agree with JamminR, VAC isn't necessary in GMod unless you're playing a competitive gamemode. :)
Offline Katie
  • Geek Girl
« Reply #4 on: October 01, 2008, 04:36:09 am »
It is on a 64bit Windows Vista Home Premium. And I want the VAC on it because we do some competitive things and I've had trouble with cheaters on Gmod before. >.> Also it doesn't look like many, or none at all , people can connect. Someone test this when you get the chance. IP is 69.253.253.133:26901
Offline WildWill
  • Global Moderator
    • Beast_Building_Server
« Reply #5 on: October 01, 2008, 07:15:59 am »
I just checked to see if it was there and alas, there it is.
« Reply #6 on: October 01, 2008, 07:59:27 am »
Are there other servers running on this machine? VAC has problems running on more than one server per machine (at least, this was the case on my box, but that was a hlds/srcds combo, maybe it's different in this situation?).
