Author Topic: Unable to use commands  (Read 13758 times)
Re: Unable to use commands
« Reply #15 on: October 04, 2008, 07:07:10 pm »
Have you edited any ULX code?
Do you have any lua files in non-addon format in gmod/lua/autorun or autorun/server?
I'm really at a loss.
If there were really an issue with ULX, there should be an error in console on server load, or at the least when you attempt to run the chat command.
I've tested latest SVN and have no issues with it in single player (other than my server.ini commands not running; mentioned in another thread.)
Offline hello123
« Reply #16 on: October 04, 2008, 08:49:53 pm »
I'm sure I didn't edit it, I can retry downloading it. I am using the addon format one. I could never edit anything since I don't know how to code anything. I'll try the SVN now and see if it works.
Offline hello123
« Reply #17 on: October 05, 2008, 11:15:53 am »
The SVN works perfectly so far, commands working in chat all the time now. Thanks alot for all your help. Great mod by the way.
