Author Topic: More issues  (Read 5233 times)
Offline Katie
  • Geek Girl
More issues
« on: October 09, 2008, 01:51:45 pm »
Now I am unable to see stool entities. I see props fine but when I spawn a wheel or thruster or any stool I see the shadow and on some I see the outline when I look at it but otherwise all of them are completely invisible. Help me  ???
"I am your shield I am your sword. Mainly because I have all the weapons and the only key to the armory and YOOOOOU don't!"
Re: More issues
« Reply #1 on: October 09, 2008, 05:37:12 pm »
When did this start? After you added an addon?
Is it on every server you join? Just yours (if you have one)? Same thing happen in single player?
Phoenix addon adds several wheels and thrusters. Changed/added it lately?
Added any 'xray' or 'invisible' addons?
Check your tab that controls visual settings. Perhaps an odd setting is on there?
Offline Katie
  • Geek Girl
Re: More issues
« Reply #2 on: October 09, 2008, 07:03:14 pm »
Okay. I fixed this issue. I accidentally up when I reinstalled gmod. But now I crash nearly 89% of the time when I open PHX general construction props (which I need) and many other menus important to me.
In short terms: Whenever I click a different spawn list, say for now Counter Strike, I immediately get 'hl2.exe has stopped working' so I can not use any props except the junk I see when I open the menu at the start.
« Last Edit: October 09, 2008, 07:15:59 pm by Katie »
Re: More issues
« Reply #3 on: October 09, 2008, 07:16:33 pm »
May be old versions of phx mixing (or other addons)
I had a spawn menu issue at one time with the same I think, either it crashed, or would just show a tiny portion of the list.
This was right after a Gmod update.
Everyone was saying 'delete all of the gmod folder and re-install clean"
I found a much simpler fix.
Unfortunately I forget the exact folder/steps I did.
Had something to do with gmod/spawnlists
Try this;
Shut your game down (presume you know that, stated for safety)
Remove _all_ but default addons. These are default;
counter-strike           by Valve, version 1 (5th August 2006)
day-of-defeat            by Valve, version 1 (22nd August 2006)
default_sent_pack        by TEAM GARRY, version 1 (3rd December 2006)
derma                    by , version 0.1 (17th July 2007)
hl2_ep2                  by Valve, version 1 (29th October 2007)
portal                   by Valve, version 1 (29th October 2007)
tf2                      by Valve, version 1 (29th October 2007)
(though you shouldn't have to remove ULX/ULib if you have it on your client game, wouldn't hurt either way)
Rename your gmod/settings/spawnlists folder oldspawnlist or something like that.
Now, once removed/backed up.. restart your game.
Spawn list should now work, albeit slowly.
In props, go to each category, let it rebuild the spawn list icons. Yes, this can take a while. It's still quicker than starting totally fresh again though.
Quit game.
Add phx back. I recommend latest if not SVN (I have no clue what latest release before SVN is)
Restart game.
Attempt spawn menu. Let it rebuild spawnlist for each icon.
Rinse, repeat for each addon that places items in spawnlist Q menu.
If that doesn't work, tell which point failed. That addon may be a problem.
