Author Topic: no access :(?  (Read 16238 times)
Re: no access :(?
« Reply #15 on: October 19, 2008, 06:17:20 pm »
Garry's code relies on the "Out"{} wrapper, not ours. We're reading the table with his function.
Either it doesn't anymore, or Garry's messed up his own code files (either is as much possible as the other)
I just checked the gmod gcf file to make sure I hadn't made an editing error then replicated to my dev folders.
The Users.txt file in /settings/ doesn't have the wrapper.
Re: no access :(?
« Reply #16 on: October 19, 2008, 07:08:41 pm »
Okay, added this to our 'todo' list. :P
Re: no access :(?
« Reply #17 on: October 19, 2008, 07:20:02 pm »
Heh, or we could just wait until Gary changes it again.
No, wait, then it would never get fixed.
We'll have to fix ours so he'll update his again and break it. :P
Stealth, the edit we had you do _may_ break you using other admin tools, including the stools menu.
Here's what I recommend;
Use ULX's adduser command from server console to add yourself to superadmin group. (See the FAQ)
Once that's done, edit your settings/users.txt file back to include no OUT { <Users superadmin you blah> }
Restart from there.
If everything seems to be working for you as is, don't worry about it then.
« Last Edit: October 19, 2008, 07:23:38 pm by JamminR »
Offline stealth7d
Re: no access :(?
« Reply #18 on: October 20, 2008, 07:26:52 am »
Worked, thx guys  :D
