Author Topic: SuperAdmin or no?  (Read 4110 times)
peukend
SuperAdmin or no?
« on: October 28, 2008, 01:11:41 pm »
I was trying to see if a super admin command would work on a server that I created through the main page of GMod, I entered the command but it did not work, is it because I need dedicated server or if there is just no super admin for the ULX mod that I have, or is the command I entered wrong?
I forgot the command seeing how I just glanced at it and entered it, could someone mind telling me the commands for Super Admin and Admin?
Re: SuperAdmin or no?
« Reply #1 on: October 28, 2008, 03:08:56 pm »
On a non-pirated latest version of Gmod as a listen server (listen = started from in a game), with latest versions of both ULib and ULX installed, you should have superadmin access.
From our Frequently Asked Questions - /index.php/board,30.0.html
What ulx commands should I see in "ulx help"? - /index.php/topic,3254.0.html
That question will show you all the commands you should see as a superadmin.
Having trouble with access? - /index.php/topic,383.0.html
That should help with access. Though meant mostly for those with dedicated servers, all the same rules apply in granting access.
