Author Topic: ULX MOTD isn't working.  (Read 8977 times)
Offline Fury
« on: November 20, 2008, 04:04:39 pm »
I currently am in the possession of an DarkRP dedicated server, and the MOTD never works.
I have the latest version of ulx, downloaded it directly from this site.
The console of my server and the console in-game have no problems (related to ulx) during the start up of my server, nor when someone joins.
When I type 'ulx motd 1' in the server console it says 'You can't see the motd from the console', is that the wrong command, or did you already know that was going to happen? When I type 'ulx motd 1' in my console in-game, nothing happens.
The only thing that I have edited in the addons/ulx folder is the motd, I edited it to my preferences and also copied it and changed the copy's name to 'ulx_motd'. Both files are in addons/ulx and orangebox/garrysmod.
I have no addons that replace ulx or motd.
List of addons:
Breakable Props Tool
Contraption Saver Tool
forcedynamite
Keypad
LampStool
Laser STOOL 2
OL_MeasuringStick
PCMod CDs
Pheonix-Storm
Uclip
ulib
Sensor Tool
Unbreakable Tool
WeightSTool
Stacker
SmartFreezer
smart_welding
wire
wire model pack 1
ulx
Simple RP Prop Protection
PropSecure
playscene
oSKARSmhiP Trails
NPC_Talk
ModelManipulator
Harpoon Tool
GME
Fading Door Tool
DoorSTool
CrateMaker
Conna's Tools Pack
Canon Tool
BridgeTool
Airbrake Tool
Adv Duplicator
[STool] Npc Control
derma
hl2_ep2
portal
tf2
legs
PCMod
So, any idea what could be the problem?
Offline johnlukeg
Re: ULX MOTD isn't working.
« Reply #1 on: November 20, 2008, 05:57:40 pm »
Hmm, strangely enough my MoTD stopped working recently as well, after installing the player possessor swep.  (http://www.garrysmod.org/downloads/?a=view&id=42720)
The problem persists even after removing it.
Also, as per your problem, I believe you are not supposed to edit the MoTD through the ULX Motd file in addons.
« Last Edit: November 20, 2008, 05:59:12 pm by johnlukeg »
« Reply #2 on: November 20, 2008, 11:00:12 pm »
ulx motd is the command to show the motd, that's why you can't use it from console. But typing ulx motd from a client has no effect, either? Does it say it's an unknown command? Any errors after using the command in either client or server console?
« Reply #3 on: November 21, 2008, 09:40:20 am »
Move your motd file to <server>/garrysmod, name it to motd.txt, remove the motd file in your ulx folder. Completely shut down and restart the server, and let me know what happens.
Offline Fury
« Reply #4 on: November 24, 2008, 08:17:32 pm »
Sorry for taking so long, but that worked, thanks jay.
Just in case this could be of use in some way in the future, nothing would happen when I typed ulx motd into console. It didn't say 'unknown command', and it wouldn't open the motd.
