UBowl v1.0
by Brett "Megiddo" Smith
Part of the Spirit of UGM collection.
This script spawns a lane of bowling pins.
Requirements:
This script requires ULib version 1 or higher. You can download ULib from ulyssesmod.net
Usage:
Use the command "makelane" to create a bowling lane, use "cleanlanes" to clean up previous lanes.
Changelog:
v1.0 *(09/12/06)*
* Initial version.
assert( _file.Exists( "lua/ULib/init.lua" ), "UBowl needs ULib to run!" )
_OpenScript( "ULib/init.lua" )
assert( ULib.ULIB_VERSION >= 1, "UBowl requires ULib version 1 or higher to run!" )
local pin = "models/mixerman3d/bowling/bowling_pin.mdl"
local ball = "models/mixerman3d/bowling/bowling_ball.mdl"
local spacing = 25
local rows = 4 -- Standard pin setup has 4 rows
local ents = {}
local function cc_makeLane( userid )
ents[ userid ] = ents[ userid ] or {}
PlayerLookTrace( userid, 4096 )
if not _TraceHit() then
ULib.tsay( userid, "Please look at where you want to spawn the lane!" )
return
local start = _TraceEndPos()
local back = _EntGetForwardVector( userid )
local right = _EntGetRightVector( userid )
back.z = 0 -- We don't care about the third dimension
right.z = 0
local ang = vector3( 0, 90, 0 ) -- Used for angles
for y=1, rows do
local odd = (math.mod( y, 2 ) ~= 0)
offy = vecMul( back, spacing * (y-1) )
for x=1, y do
local offx
if x == 1 and odd then -- We just go straight back
offx = vector3( 0, 0, 0 )
--ULib.print( "easy way out" )
--ULib.print( "x =", x, "y =", y, "offx =", offx, "offy =", offy )
local direction = math.mod( x, 2 ) * 2 - 1 -- Go right on odd numbers, left on even, timesing by two makes it 1 or -1
local offnum
if not odd then -- We need to add one to account for the middle pin
offnum = x + 1 - math.mod( x + 1, 2 ) -- This rounds down to the nearest multiple of 2
offnum = x - math.mod( x, 2 ) -- This rounds down to the nearest multiple of 2
offnum = offnum / 2 -- And this gives us the number we want
if not odd then offnum = offnum - 0.5 end -- For those odd rows!
offx = vecMul( right, spacing * offnum * direction )
--ULib.print( "odd =", odd, "direction =", direction, "offnum =", offnum )
local pos = vecAdd( start, vecAdd( offx, offy ) )
table.insert( ents[ userid ], ULib.makeProp( pin, pos, ang ) )
--ULib.print( pos, "\n\n\n" )
ULib.CONCOMMAND( "makelane", cc_makeLane )
local function cc_cleanLanes( userid )
if not ents[ userid ] then return end -- Nothing to do
for _, entid in ipairs( ents[ userid ] ) do
if _EntExists( entid ) and (_EntGetModel( entid ) == pin or _EntGetModel( entid ) == ball) then -- No exploiting here!
_EntRemove( entid )
ULib.CONCOMMAND( "cleanlanes", cc_cleanLanes )
